I have no idea what you people are talking about or why playlists matter. It's an incorrectly authored menu button.
Results 31 to 35 of 35
Well I thought I had already explained that way back in reply #11 >> Two disks that respond incorrectly to menu selections and neither of which I think were authored incorrectly.
But I will leave this topic now (you will be pleased to read) since you can not or will not accept that logic. -
Reply #41 discusses MakeMKV's handling of DVDs, which MakeMKV will only rip in MKV format. I think this is a choice made by the developer, possibly because there are plenty of other programs that can rip DVDs in their entirety as files and folders but few that can decrypt a DVD and re-package the video as MKV files.
MakeMKV allows Blu-ray to be ripped either as individual videos in MKV files or as files and folders containing everything on the disc, including menus.
Ripping individual videos from Blu-ray as MKV files would certainly require using playlists. However, copying the entire contents of the entire Blu-ray disc, including the menus, as files and folders shouldn't require navigating any playlists.
I very much doubt that MakeMKV would introduce menu navigation errors into the file and folder copy, and PowerDVD would play the copy without encountering any region code conflicts. If there are menu navigation errors in the copy, they would have to be present in the original too.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Just remembered I have the DVD version of this set from before I got a region free Blu-Ray player. Those menus are authored correctly, so I could get the info that way. Doesn't answer the actual question but does solve my problem.
I'm glad that you found an answer.
BDEdit could be an answer for some people but obviously it is not an answer for everyone because for this solution to work, the Blu-ray disc's menus have to be Java-based and the user needs to be knowledgeable enough to figure out how to use the program and must know how to interpret and correct the menu commands. However, if someone is able to successfully use BDEdit to correct the commands then PowerDVD would be used to play the corrected copy of the disc stored on their HDD and see the formerly inaccessible menus.Ignore list: hello_hello, tried, TechLord, Snoopy329
Blu-ray Menu Screenshots: Is there any hope?
By User897 in forum Blu-ray RippingReplies: 17Last Post: 30th Aug 2019, 10:29 -
Weird problem converting / extracting Marvel's The Avengers Blu-Ray
By EmmB in forum Video ConversionReplies: 0Last Post: 8th Jun 2019, 22:31 -
Is there a way to take a screencap of a blu-ray menu?
By Hatteras in forum Newbie / General discussionsReplies: 5Last Post: 4th Feb 2018, 21:30 -
TMPGEnc Authoring 5 Blu Ray Menu Help
By jimmyboyl in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Mar 2017, 19:18 -
Seeking help with authoring a Blu-ray with menu and chapters
By Schmidty3634 in forum Authoring (Blu-ray)Replies: 0Last Post: 6th Jun 2016, 17:37
