Hey, I downloaded a video from the net which is progressive in format but interlaced. The people who rendered it messed it up big time. Also, it only gets deinterlaced when I use both the TFF and BFF at the same time, I have no idea why that happens. I know about AviSynth and StaxRip but don't have much experience with them that's why I can't find a solution. What can I use to get the best possible results? I have attached a short clip from the video for anyone to try. I would really appreciate it if anyone can help. Thanks
Interlaced SD PAL video was upscaled incorrectly. The general procedure is to downscale to 576 lines, deinterlace, then (optionally) upscale back to the original frame size. The results won't be as good as if you had started with the original 576i video. I didn't make any attempt to fix the aspect ratio problem.
video analysis and deinterlacing (1080i)
By trispel in forum Video ConversionReplies: 5Last Post: 22nd Oct 2019, 06:58 -
Deinterlacing an online video with comb artifacts?
By Master Tape in forum RestorationReplies: 4Last Post: 21st Jul 2018, 03:48 -
Joining, deinterlacing, and encoding MOD source files to progressive h264
By nicholasserra in forum Video ConversionReplies: 45Last Post: 5th Dec 2017, 11:41 -
Deinterlacing a progressive clip
By vipren369 in forum Capturing and VCRReplies: 14Last Post: 8th Sep 2017, 07:16 -
Deinterlacing inverse telecined video
By Colek in forum Video ConversionReplies: 4Last Post: 9th Aug 2016, 08:51
