  1. I switched from win7 intel to win10 amd. tried opening a script and got this. Avisynth is 2.6mt. tried both old/new megui portable 32bit. was working on intel
    see untitled1
    LoadPlugin("V:\dvds\filters\Decomb521VFR1.3_P4-Athlon.dll") #line3
    if i switch to a newer one. see untitled2
    LoadPlugin("V:\dvds\filters\Decomb524.dll") #line3
    #line15
    Decimate(mode=4,threshold=1.4,quality=3,timecodes= "V:\B\9\B9.txt",
    \vfrstats="V:\B\9\B9.vfrstats")
    Aug 2013
    Central Germany
    "Module not found. Install missing library?"
    I guess if you had searched for these keywords, you may have found a hint that you may need to install the required Microsoft Visual C++ Runtime library (discovering which version exactly may be harder; just install them all, both x86 and x64...).
    And for the most recent version, the Reference Manual (found in the AviSynth Wiki about Decomb).
  3. Thanks, I thought i got everything. Nope, two missing dll files fixed it. msvcr71, msvcp71
    megui needed a upgrade to 29.* (from 2402 lol)
    put them in sys32/64
