Hi, would it be possible for someone here to fix the ABC.com site?
videos that are available for free wont download ytdl is asking for account login (free episodes play fine through a web browser)
sample https://abc.com/shows/marvels-agents-of-shield/episode-guide/season-07/01-the-new-deal
The site hasn't worked for a few weeks and the devs of ytdl still haven't fixed it
Someone did post a fix on the ytdl github page but it hasn't been applied to the original ytdl.exe
Here is the topic www.github.com/ytdl-org/youtube-dl/issues/25436
Would someone be able to apply the fix to the ytdl.exe software? i don't know any other way to download them (IDM, doesn't work) does anyone know of other software/add-ons that can?
Here is the link to the fix on github if anyone could apply this then ABC should work again
i have no idea how to use the fix i know how to use the normal version of ytdl and thats about it
and i could not ask for help there as i didn't have an account and when I created one it wouldn't let me post a reply because it was a new account weird
https://github.com/ytdl-org/youtube-dl/issues/25436
Thank you
if you read the last comments https://github.com/ytdl-org/youtube-dl/issues/25436
the patch/fix is still not working. -
3 different members are saying it worked for them and the very last post I'm sure is talking about the newly released ytdl (6-6-20) saying abc is still not working using that version if so is because the devs haven't coded that fix into the official release I've read the recent logs and no there is no mention of Disney/ABC
youtube-dl-2020.06.16.exe
youtube-dl-2020.06.06.exe
youtube-dl-2020.05.29.exeLast edited by blade2005; 19th Jun 2020 at 10:33.
assuming that you're running the standalone windows exe version of youtube-dl?
Instead, install the python version of youtube-dl.
The steps to do so are not that difficult. For an overview, watch this video: https://www.youtube.com/watch?v=5rRxDD7MDE4
Essentially, python is installed first, after which the python version of youtube-dl is installed using pip:
After the python version of youtube-dl is installed, a small stub executable "youtube-dl.exe" is created, usually in the python directory ending in "\Scripts". In order to be sure that some other prior version of youtube-dl is not run instead, rename all prior versions or move them out of your path.Code:pip install youtube-dl
Run the python version of youtube-dl at least once, without any command line arguments.
Next, find the extractor directory for the python version of youtube-dl, it is usually in the python directory ending in "Lib\site-packages\youtube_dl\extractor".
Find go.py within the extractor directory.
Using idle.bat (the python editor) or perhaps notepad++ (idle is preferred because notepad++ can sometimes mess up the formatting), perform the following edit on go.py:
Change:
to:Code:r'\b(?:video)?id["\']\s*:\s*["\'](VDKA\w+)'
See reference for the above edit here: https://github.com/ytdl-org/youtube-dl/commit/5a3e2a4fb1f7ad7e0db7df927bb20464260ad271Code:r'\bvideoIdCode["\']\s*:\s*["\'](vdka\w+)'
Save the edit to go.py. Now the python version of youtube-dl will download your video (up to 720p, 1080p is dash only).
I've confirmed that this edit does work on the example video in your post. -
Thank you so much for the understandable step by step instructions
I don't know.
You can take the uplynk child m3u8 url (h.m3u8, i.m3u8, j.m3u8, etc.) that is discovered by the python version and then use it with the standalone windows .exe version (with --hls-prefer-native) and then the native hls downloader seems to work. I don't know (yet) why it doesn't work with the python version. -
1. pip install pycryptodome
2. pip install pycryptodomexLast edited by LZAA; 6th Jul 2020 at 06:04.
Subtitles from ABC
By Boldest06 in forum SubtitleReplies: 2Last Post: 20th Nov 2019, 15:46 -
I ask for help to download a video from ABC
By Boldest06 in forum Video Streaming DownloadingReplies: 12Last Post: 19th Nov 2019, 11:45 -
Movie music too loud but dialogue too quiet fix needed
By hokkom in forum AudioReplies: 121Last Post: 4th May 2019, 08:51 -
How to download videos from ABC site in HD?
By AngelofDarkness in forum Video Streaming DownloadingReplies: 5Last Post: 23rd Mar 2018, 03:18 -
Capturing from websites: history, nbc,abc ,etc
By RBCC in forum Capturing and VCRReplies: 0Last Post: 8th Nov 2017, 20:48
