Hello everybody,
I use a little cam to capture wild animal (hedgehog here), but during the lecture, my video is shifting... (si the attachment)
Can you help me to correct that? is there a specific tool ?
Thank you in advance for your help,
Math
Results 1 to 12 of 12
In fact quite nothing!
I can just modify the resolution setting...
http://www.cnsuntek.com/uploadfiles/file/20170912/HT-001%20User%20Manual.pdf -
2 Ideas: Firmware update, use power adapter instead batteries. Your Sandisk card should be fine.
Thanks for the answer, I will try an update of the firmware!
let's hope that it is not the camera itself! -
Hello, I put the resolution on 720p (instead of 1080p) and It works very well...
Well it seems that the 1080p does not work... I had not notice that it was 720p
Video is interlaced but video header states progressive.
By Imy in forum Newbie / General discussionsReplies: 0Last Post: 25th May 2020, 17:42 -
Do you need to Deinterlace when Downscaling Progressive Video?
By VideoFanatic in forum Video ConversionReplies: 7Last Post: 8th Apr 2018, 16:43 -
help for combing/etc from progressive video
By spiritgumm in forum RestorationReplies: 10Last Post: 6th Nov 2017, 16:50 -
Video Problem, Shift? Drift? Not sure what to call it....
By Owen Plato in forum Newbie / General discussionsReplies: 17Last Post: 1st Mar 2017, 18:55 -
how do i use ffmpeg to see if a video is interlaced or progressive ??
By oduodui in forum EditingReplies: 3Last Post: 30th Jun 2015, 06:33
