So I've been recording 1080i video with Amarec for a long time now but since I'm using UTVideo as my codec it's lossless which means huge file sizes. I know I can compress later but personally I'd rather have a good lossy codec than lossless for HD. I know lossless is the best but the hard drive space is crazy (250gb+ for a 2 hour recording). My capture card's an Elgato HD60s. I would use the Elgato Game Capture software but unfortunately it doesn't record to an interlaced file (at least for the HD60S) + there's color trailing issues (mainly due to recording in YV12. Recording in YUY2 with Amarec doesn't have any issues even though the capture card is actually interally YV12). Does anyone know any good lossy codecs or software that can record to an interlaced file? I remember trying ffmpeg a long time ago but I have to crank up the bitrate to 200mbps to get a file that isn't blurry.
I experimented with MPEG2 a while back with ffmpeg, I'm not sure if I'm doing it right but that's where I had to crank the bitrate to 200mbps to get a good result. Either that or I'm going crazy
Here's my batch file at the moment
Code:ffmpeg -f dshow -rtbufsize 2048M -r 29.97 -i video="Game Capture HD60 S (Video) (#01)":audio="Game Capture HD60 S (Audio) (#01)" -c:v mpeg2video -q:v 0 -b:v 60000k -minrate 60000k -maxrate 60000k -flags +ilme+ildct -top 1 -f segment -segment_time 362439 -strftime 1 "output\%%Y-%%m-%%d_%%H-%%M-%%S.ts"
Is there really anything I need to change? Or is there a way to record MPEG2 in Amarec? I would go with the firewire route for the best results but I can't be bothered to swap my firewire card out from my main PC to my XP machine (since there's no 64-bit cable box firewire drivers), and Spectrum copy protects every channel that isn't local channels. -
x264 with the --tff command can be used to record 1080i content. It supports YUY2 too. I use it regularly for VHS recording on the fly. As I normally record 480p, the CPU demands are going to be much lower than your use case of 1080i so start off with the fastest preset and go from there.
You need x264vfw installed for it to work in Amarec. Put the --tff command into the extra command line box, along with the zero latency box checked. Maybe use a CRF of 18-20. -
I haven't used it in many years but PicVideo MJPEG might work. I definitely supports 4:2:2 chroma subsampling. Also 4:2:0 but they call it 4:1:1.
Well it looks like I'm probably gonna stick with ffdshow and mpeg2. Seems to be working well but I'm having some audio sync issues. Sometimes it's fine and at other times it's messed up. Anyone have any ideas on how to fix that?
Code:ffmpeg -f dshow -rtbufsize 1000M -r 29.97 -i video="Game Capture HD60 S (Video) (#01)":audio="Game Capture HD60 S (Audio) (#01)" -c:v mpeg2video -q:v 0 -b:v 200M -minrate 60M -maxrate 200M -c:a pcm_s16le -flags +ilme+ildct -top 1 -f segment -segment_time 362439 -strftime 1 "output\%%Y-%%m-%%d_%%H-%%M-%%S.mkv"
A (Most Likely) Dumb Question About Re-encoding Lossy Formats
By enter8 in forum Newbie / General discussionsReplies: 4Last Post: 18th Sep 2019, 19:11 -
MSU Video Codecs Comparison 2019 - CALL FOR CODECS
By DmitriyK in forum Latest Video NewsReplies: 0Last Post: 19th Feb 2019, 02:25 -
ffmpeg: how to avoid transcoding from a lossy format?
By Luke M in forum AudioReplies: 3Last Post: 11th Dec 2018, 17:28 -
Help me with 1080i to 1080p
By cybero75 in forum Video ConversionReplies: 8Last Post: 6th Mar 2016, 08:35 -
PotPlayer - ZMBV poor/lossy color reproduction?
By largactyl in forum Software PlayingReplies: 8Last Post: 5th Jul 2015, 03:45
