Results 1 to 17 of 17
  1. Hi,
    I’m looking for a way to change subtitle’s font to a specific type that’s not available neither on Samsung TV or plex media server, but unfortunately with no luck so far.
    The way I’m using now is merge srt with mkv file and play it directly from Harddrive to Samsung tv pr some times using plex media server.
    canada
    Try universal media server,it has font settings you might like.
  3. Sure I will try it, but I belive I’ll face some difficulties with it as my server is on WD My home cloud I’m not sure if this server supports it. Is there another way to include the font with subtitle ?
    Thank you for the suggestion I Really appreciate it.
  4. try kodi
    or
    repack mkv with font inside
  5. Originally Posted by paso77 View Post
    try kodi
    or
    How can I repack the font inside ?
  6. Last edited by paso77; 19th Jun 2020 at 18:55.
  7. Originally Posted by paso77 View Post
    Thank you, I just tried it convert the .srt to .ass and attached the font file and merge them, unfortunately didn't work
  8. try to use srt no ass
    or
    try to use ass with attached font
    EDIT
    tomorrow I also try out of curiosity....goodnight....
  9. Originally Posted by paso77 View Post
    or
    EDIT
    I attached the font with .ass itself but didn't work. I also attached with mkv file along with .srt file and didn't work as well.
  10. ass file without font inside mkv (on pc is regular)
  11. after delete font from pc
  12. mkv with inside font
    photo test (sorry screen srt but I used ass)
    EDIT
    I try to use srt but don't work
  13. Originally Posted by paso77 View Post
    EDIT
    Yes this already working with me on pc but what I asking about here is on Samsung smart tv directly or via plex.
  14. Originally Posted by Mishari View Post
    Hi,
    I just purchased a Samsung QLED Smart TV and although the new ones will not play IDX/SUB subtitles like my old one did they do have more options for text based subtitles. Changing font is one of them. It is a limited selection though. You can also change color, size, border, background, etc. it’s best to have the subtitle file named the same as the movie. It will play embedded subs but not as well as a separate file.
  15. Originally Posted by Mishari View Post
    if tv is not compatible the only way is hardsub
  16. sorry, model of samsung ???
    read .sup file (BD format) ???
