hello good afternoon, I am extrallendo a chapter of a dvd, it is a concert of mj, my doubt is, when playing it in MPC-HC the concert is seen at 60fps, but when going to the information of the file in mediainfo it gives me frame rate : 29fps, how can I extract it in mp4 at 60fps? or mkv at 60fps? Thank you
Your DVD contains interlaced video at 29.97 frames per second. Each frame of interlaced video contains two separate half-images, called "fields", intended to be viewed separately, and sequentially, at 60 "fields" per second. That is what MPCHC is showing. If you "extracted" the original MPEG 2 video intact it is still interlaced and should be played back at 60 fields per second. If you converted it to something else you may have deinterlaced to 29.97 fps.
wget behaviour is different when poll for a TS fragment
By Dave1024 in forum Newbie / General discussionsReplies: 0Last Post: 20th May 2020, 10:30 -
How to scale the fragment of the video without cutting it
By JohnPix2 in forum EditingReplies: 0Last Post: 18th May 2020, 01:48 -
What software encodes 4K 60FPS HEVC @ 60FPS?
By Davekyn in forum Video ConversionReplies: 6Last Post: 7th Apr 2020, 11:25 -
Youtube-dl ERROR: giving up after 10 fragment retries
By FernandaLobo in forum Video Streaming DownloadingReplies: 6Last Post: 18th Jun 2018, 22:48 -
How to make a slow-motion fragment in VSDC Free Video Editor?
By Katty.Fine in forum EditingReplies: 2Last Post: 10th Jun 2016, 05:14
