Are these not good to get? I noticed that SIIG & QPS's firewire cards are using TI boards.
Can anyone add any information on these? Is there a brand that doesn't use TI boards?
Thanks,
John
If ...
- You're really don't want to go for a TI Firewire chip
- You'll be doing DV transfers only
- You don't really care about price
I'd recommend a DV-Only firewire card like the Canopus EZDV. Runs for $200, but it's WELL WORTH IT!!! Lives up to her name (easy). You won't be able to use the MS codec (which is the neat part), as she uses the Canopus DV Codec. -
Price is a factor unfortunately. I've already invested too much in a camcorder with a pass-thru too buy a $200 firewire card.
Can anyone recommend a specific firewire card that will be used for DV editing?
Thanks,
John -
Don't know what the problem is. I use a Pyro firewire card, cost £40, has the Texas chip and works great.
TOMMO
asus am3 boards gain bulldozer support
By deadrats in forum ComputerReplies: 1Last Post: 25th Mar 2011, 23:08 -
Embedded Boards
By Ozzyjim in forum ComputerReplies: 3Last Post: 7th Mar 2010, 00:47 -
Google Ad Sense Message Boards Fraud
By infomax467 in forum Off topicReplies: 5Last Post: 14th Sep 2009, 21:40 -
R there good and bad firewire PCI cards??
By sdsumike619 in forum Capturing and VCRReplies: 3Last Post: 3rd May 2008, 15:25 -
Cards and Boards For Basic editing rig
By Dash1 in forum ComputerReplies: 2Last Post: 10th Oct 2007, 11:12
