Hi,
i tried the above software, but could not get anytthing if i click the button to save the subtitle as srt file in a txt format, as given in he tutorial.
the help file is not in the software, but i saw it on net and tried.
i just opened the video file containing hard coded subtitles
then i just fastfarwarded the video .
j just go to ocr tab and then clik the button that says click to save as sub file images or something to that effect.
there was nothing progress shown , and there is no file in the said output folder.
would someone, clearly say, how to extract hard coded subtitles from video.
i just want srt files and so , would like to have the solution to that part.
if somebody explains it menu wise, i will be happy to follow
https://www.montgomerycollege.edu/_documents/offices/elite/hardcodedvsclosedcaptionswhatissrt.pdf
What type of file format?
Can you turn the subs on and off?SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Hi, the video format is mp4. will it not supported by the videosubfinder
i already told that i have used the videosubfnder, but could not make it work in saving as srt file.
what i want is step by step procedure. there is one video, but it has no sound help
the pdf is of portugese language which i do not know
could somebody say , how to go to the menus one by one to accomplish.
i know that it extracts hard coded subtitles , but i want to know , which buttons are to be used to get it done. -
Hi, this is the link from where i got the clue . i am not able to understand the menus and so I ask. Just clicking the sub txt as in the page link does not show any progress bar and even after minutes, if i check the folder, it is empty.
https://jurnsearch.wordpress.com/2020/03/29/how-to-extract-hardcoded-subtitles-from-an...#comment-18338 -
I am starting to use it and so far my only problem has been the txt files not showing. But everything is working it seems.
I don't know how to set the background or size yet but my compliment is minimal so far.
I am using an older version because I have a slow computer. I think later versions require you have a good gpu. Maybe that's been your problems?
How to remove hard coded subtitles ? HELP PLEASE
By TIMETHIEF in forum SubtitleReplies: 28Last Post: 2nd Jul 2020, 11:24 -
Best tool to OCR hard-coded subs in MP4 where the position & size floats?
By EmmB in forum SubtitleReplies: 4Last Post: 6th Jan 2018, 14:26 -
XMedia Recode Hard Coded Subs
By TheRandomOne in forum Video ConversionReplies: 2Last Post: 18th Mar 2016, 23:04 -
Hiding hard-coded subtitles
By MikeBintouch in forum SubtitleReplies: 16Last Post: 15th Mar 2016, 05:00 -
Hard Coded Letterboxing
By danielnitschke in forum EditingReplies: 4Last Post: 6th Jul 2015, 01:30
