I have many MKV files with video at 23.976fps but I believe the subs are at 29.97 fps because occasionally a line of dialogue will fail to display (and that's what the original video frame rate was before my detelecine and decimate). Is there a way to convert the subs to the correct frame rate via the command line?
You could use Subtitle Edit with the optional parameter /fps
Code:Subtitle Edit 3.5.14 - Batch converter - Usage: SubtitleEdit /convert <pattern> <name-of-format-without-spaces> [<optio nal-parameters>] pattern: one or more file name patterns separated by commas relative patterns are relative to /inputfolder if specified optional-parameters: /offset:hh:mm:ss:ms /fps:<frame rate> /targetfps:<frame rate> /encoding:<encoding name> /pac-codepage:<code page> /track-number:<comma separated track number list> /resolution:<width>x<height> /inputfolder:<folder name> /outputfolder:<folder name> /overwrite /forcedonly /multiplereplace:<comma separated file name list> ('.' represents the de fault replace rules) /multiplereplace (equivalent to /multiplereplace:.) The following operations are applied in command line order from left to right, and can be specified multiple times. /ApplyDurationLimits /FixCommonErrors /RemoveLineBreaks /MergeSameTimeCodes /MergeSameTexts /MergeShortLines /ReverseRtlStartEnd /RemoveFormatting /RemoveTextForHI /RedoCasing Example: SubtitleEdit /convert *.srt sami Show this usage message: SubtitleEdit /help List available formats: SubtitleEdit /help formats -
An IVTC doesn't change the length of a video file. Therefore, changing the sub timings will do nothing but ruin them and won't solve whatever problem it is you have.
Are those subs from the same source as the audio and video? A DVD perhaps? Or were they downloaded separately? -
Yeah, everything is from the same DVD. The IVTC video is originally from a VOB file while the audio and subs are from a .mkv ripped from the DVD with MakeMKV. They were muxed together with mkvmerge. Maybe getting the subs from the VOB as well would solve the missing lines issue?
How do I convert MKV to MP4 in batch with burned-in subs? (Vidcoder)
By fighuass in forum Video ConversionReplies: 12Last Post: 29th Aug 2021, 12:02 -
Hardcoding subs into an MKV file
By Slevin in forum SubtitleReplies: 4Last Post: 11th Jun 2020, 03:52 -
Taking subs from mkv A and B to replace subs from mkv C in a different lang
By Boxgoblin in forum SubtitleReplies: 2Last Post: 26th Nov 2017, 12:00 -
DVD(Video_ts) with subs to a file with hardcoded subs?
By hech54 in forum SubtitleReplies: 3Last Post: 30th Aug 2016, 14:45 -
How do I convert DVD subs into BD subs?
By Patapin in forum SubtitleReplies: 2Last Post: 3rd Oct 2015, 11:26
