Hi,
I want to make a svcd with two audiostreams. My problem is I don't know how to include these into the menu. I would like to make the menu like a dvd-menu where you can choose between two different languages.
Can anyone tell me how to make this?
Thanks in advance.
That's not possible. The only way to select which audio stream you want to play is to hit the audio button on your remote or switch audio channels using your dvd player settings menu.
As far as a menu is concerned the best you can do is make a still picture that says "Use Audio Button," and list the possible tracks.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
