I have a problem with AVStoDVD. The video is just black but the audio is playing fine. I am trying to create dvd from an mp4-file. Attaching the log-file.
Make sure the system can decode the source video properly.
Load the project then select Codecs/build Directshow filters graph
Once the graph has loaded, hit the play button and it should play the video in a window, picture and sound
Have you tried playing the dvd and/or the Video_TS folder on the computer in VLC, mpc-hc or mpc-be ? -
I would suggest you upload as an attachment a short sample from that .mp4.
Use avidemux A/B to mark the section and use 'copy' for video and audio with mp4 as output format.
The log does not give much info about the video except it is 50 fps. You can get more info from Title >> View Title info and also preview the title from Title >> Preview Title Output. So both of these will also help. But a short sample will be the most useful.
Black Screen, audio working
By ClarkDevlin in forum Software PlayingReplies: 8Last Post: 29th May 2019, 01:56 -
Vdub displays black screen for DirectShow Capture, works for VFW
By skatingrocker17 in forum EditingReplies: 0Last Post: 3rd Jun 2018, 21:32 -
Convert Video Specs - 44.1k and Ends with Black Screen
By jgiannis in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2018, 23:11 -
Video player that transits from one video to another without a black screen
By remtin in forum Software PlayingReplies: 4Last Post: 15th Dec 2016, 10:45 -
Video Doesn't Fill Screen, Black Bars on All Four Sides
By lomaidala in forum DVD RippingReplies: 17Last Post: 24th Jan 2016, 13:55
