Hi there,
I have a Logitech C920 "s" (follow-up model but supposed to have same specs as the C920) which does not want to offer me smooth continuous playback in various applications. It just omits frames randomly, like 1-5 in a row (3x in a sec, every 2nd sec, etc.). I am almost there saying the freaking camera just canīt do it.. but I saw YT Videos of the C920 that seemed fine.
I tried a lot of things:
- using MJPEG of course is the way to go, it wonīt work otherwise
- various capture software on Windows 10 Pro: OBS, VLC, Logitech Capture, Windows Camera
- OBS and VLC on Ubuntu
- used at least 4 different PCs
- new and old Logitech drivers and App
- plugged into USB 2.0 ports
- changed parameters on Cam: deactivated low light compensation and automatic exposure
- lower res (720p) and different fps (25/30)
- counter checking with another webcam, cheapo style does continuous frames but of course the image is bad..
Do you have any more ideas?
Itīs a bit weird I donīt get this working..
Cheers
	Sounds like you might have timing/overhead issues with your USB 2.0 ports. If the subsystem cannot keep up with the set codec & bitrate requirements, that is exactly the kind of stuttering/framedropping you would experience.
 Have you tried putting this cam on a usb 3.0 port?
	Hi,
 yes it actually looks like the bus is clogged. Especially because the stutter gets more when there is movement in the scene.
 But- I tried on various machines with USB 2.0 and USB 3 ports..
	Way to really isolate this when troubleshooting is to use known good substitutes: diff cam on same machine, same cam on diff machine.
 Have not encountered that with my C920, C925/922, C930 or BRIOs. Don't have the "s" model though. Sorry that's not much help.
  How to recover raw Logitech webcam footageBy JJonah in forum Video ConversionReplies: 7Last Post: 20th May 2023, 08:15
  Logitech C922 at 60fps?By EssKayKay in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2019, 12:34
  Dropping frames using madvr in MPC-HC in 4k@24 HDRBy bossystyle in forum Software PlayingReplies: 0Last Post: 24th May 2019, 17:45
  AmarecTV freezing, dropping frames, and not functioning at allBy ArianK in forum Capturing and VCRReplies: 2Last Post: 23rd May 2018, 17:32
  Potplayer+Logitech Z906 5.1, audio config assiatantBy Kenshin1870 in forum Software PlayingReplies: 0Last Post: 12th Mar 2018, 21:33
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
