Hi folks...
I have a Vixia HV30 mini-DV camcorder. Yeah, I know it’s old, but I love the picture quality and I can’t afford to buy a new camera. I recently had a repair done to it though since it lost the ability to record properly (this was back in May by a repair shop called, straightforwardly, Camera Repair in Glendale, CA).
Last night, I wanted to dump some of my video onto my PC via the FW800 port. Neither WinDV nor HDV ‘saw’ the camera. They did before the repair. And, I noticed that the small FW port in the back of the camera seems a little loose. It was not like this before to the best of my memory. I did try varying the order of events, like when the camera was turned on, plugged in, software booted up, etc. No combination made any difference.
Obviously none of you can diagnose the precise problem just by reading this post. But, I need thoughts, suggestions, perhaps if any of you have experienced something similar... so that I can decide on a course of action.
I live in Mesa, AZ, so going over the shop in Los Angeles is prohibitively difficult. Besides, I'm not sure I trust these characters anyway if something is indeed wrong with my camera. I've left messages with three repair shops within the Phoenix area, however.
Thanks for your time guys.
Keith
If you can't go back to the shop and cannot do it yourself the only thing left to do is buy another camcorder and move on.
if the firewire connector is loose in the cam, the socket has broken off the motherboard. it was only surface soldiered on and they were easily knocked off.
Few years ago I sold my HDV camcorder and bought the Sony HVR-M15AU plays DVCAM, DV, HDV, miniDVCAM, miniDV, miniHDV cassettes in both PAL and NTSC formats, and it plays the 1080p (24p, 25p, 30p) the rare format that few consumer and pro camcorders recorded, There is an NTSC version only (I forget the model #) but you can tel from the back, The US version has 4 pin firewire connector and the PAL/NTSC version has a 6 pin fw connector.
https://www.ebay.com/itm/Sony-HVR-M15AU-NTSC-PAL-1080i-HDV-DVCAM-DV-Digital-Video-Play...kAAOSwB7le5qOe -
Dellsam, thank you. I'm going to have a local camera repair shop look at this thing, probably this weekend. But, your route may wind up being the way I have to go. Thank you.
This camera though has two other outputs for HD: HDMI and composite (though the out-port on the camera's for a 1/16th" jack; however, the output on TVs from the RGB jacks at the other end at least is usually pretty good). I'm wondering if one of those might serve as an alternative.
I'll find out this Saturday, but I welcome any other thoughts -- but buying a new camera's not going to happen at this point in time. I just don't have it.
Thanks folks. -
Cannon vixia hf r82
By Rick1 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Mar 2020, 10:28 -
Canon HV30 stops recording
By philbu in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Oct 2017, 13:52 -
Cannon Vixia RF82
By rrtbusa in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 23rd Sep 2017, 15:46 -
Occasional stutters when playing HDV files using VLC from Canon HV30 in 30p
By XperienceD in forum Software PlayingReplies: 5Last Post: 8th Jan 2016, 17:42 -
Canon Vixia G20 Help
By Rayhbez in forum Newbie / General discussionsReplies: 6Last Post: 21st Dec 2015, 15:49
