    Jun 2020
    Hong Kong
    Is there a software allowing me to have different offset at different part of the video?
    e.g.
    offset 1000ms from 00:00:00 to 00:30:00
    and offset 2000ms from 00:30:00 to 00:45:00
    I've consider to convert it to vobsub but the result is quite ugly...
  2. In Subtile Edit import your .sup file. Make an OCR. Turn "Prompt for unknown words" off. Edit the subtitles to get the timing you want.
    [Attachment 53817 - Click to enlarge]
    Reload the sup file and import the new time codes.
    [Attachment 53818 - Click to enlarge]
    Then export the file.
    [Attachment 53819 - Click to enlarge]
    Jun 2020
    Hong Kong
    But this will align all lines at the same position but I would like to keep the position of the sub.
  4. Then I must have misunderstood what you want to achive. Sorry.
  5. thx videobruger
