:o Does anyone know of any software that can loop video clips so that
they are in perfect sync. For example,I want to show some rhythm guitar parts to a student that will loop over and over smoothly so other parts
can be played live with them. What I guess I'm looking for is something that will handle video clips like Sonic Foundy's ACID does to audio clips.
Thanks.
that would be practically impossible, when it jumps from the end back to the beginning, the video would be jumpy. It doesn't matter how still the person is. The end frame would have to be virtually identical to the begining frame to look natural
Thanks Liquid,
I could live with the slightly jumpy video as long as the audio portion
is seemless with no delay.
I have Pinnacle Studio7 which can play loops when in edit mode; but
there is a timing lag between the end and start points which throws the music off.
I read elsewhere that Premier 6.0 and Ulead's Media Studio Pro 6.5
can do it, but these two programs are way out of my price range.
Do you know of any freeware or software under $100 that can do
the job? -
Why not download the trial versions of Adobe Premiere 6 or Uleads Media Studio Pro and see if they really do what you want?
Regards: Patsym1 -
Will the TRIAL versions of Premier 6.0 and Media Studio Pro6.5
expire after a period of time and/or be limited in some functions(such
as saving projects)?
Video Loops Background
By wwaag in forum EditingReplies: 4Last Post: 23rd Sep 2010, 20:22
