Hello,
I recently found a Panasonic DMR ES15 at a thrift store and heard that these devices are great for video passthrough, but I'd like to use its DVD drive for recording VHS video. Interestingly, this unit doesn't suffer from the U61 error, but instead it intermittently reads discs. Majority of the time the unit displays a "No Disc" error. When it displays this error, it seems like the laser transport isn't even trying to read the disc at all, which sometimes leads to the unit trying to read a disc even when the tray is open. But when it does work, it is able to perfectly function and do everything including play record and finalize discs. So this makes me believe that the issue isn't the laser, but maybe the transport. Has anybody experienced this issue where the DVD drive intermittently works? Help would be appreciated.
I'd like to add that I notice circular scratches on the disc after inserting the DVD, hopefully that will serve as helpful info.
Results 1 to 1 of 1
Panasonic DMR-ES15 PAL - how to setup for TBC passthrough
By spotty in forum Capturing and VCRReplies: 9Last Post: 30th May 2023, 05:06 -
Panasonic DMR-ES10/ES15/ES20 PAL-N compatibility
By Crisrodd in forum Capturing and VCRReplies: 5Last Post: 26th Oct 2019, 14:05 -
Need help fixing Panasonic DMR-ES15 drive (video of issue included!)
By Bassquake in forum DVD & Blu-ray RecordersReplies: 6Last Post: 25th Jul 2018, 17:33 -
Turn off Panasonic DMR-ES10, ES15 power-off feature
By bhershey in forum Capturing and VCRReplies: 2Last Post: 24th Apr 2018, 18:33 -
Is there a Windows 7 driver for Panasonic DMR-ES15?
By digicube in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Apr 2017, 19:59
