Closed Thread
  1. Banned
    Jun 2020
    España
    Hello how are you? I do not know if it is better to open a thread about this or put it here, well, my question is about what is the method to capture from the web "zbiornik.tv" I tried with several softwares dedicated to this end and I did not get any results, before you could capture or download the streaming using "rtmp" but apparently they have masked that now there is no way, similar happens with "ShowUp.tv" but the latter if I can capture. Thank you.
    Hola como estan? no se si mejor abrir un hilo sobre esto o ponerlo aqui, bueno , mi pregunta es sobre cual es el metodo para capturar de la web "zbiornik.tv" intente con varios softwares dedicados a este fin y no consegui ningun resultado , antes se podia capturar o bajar el streaming mediante "rtmp" pero al parecer lo han enmascarado que ahora no hay forma , parecido pasa con "ShowUp.tv" pero de este ultimo si puedo capturar. Gracias.
    canada
    Alex Lenovo-please do not ask for help on downloading videos from a porn site,this is against forum rules,this thread is closed.
