I made a video on my Samsung phone but after transfering it to PC it is now very wavy like it has water effect is there a way to fix it?
Short clip of the video is here https://www.moveitcleanit.co.uk/wavy.avi
This is not the original phone recording. How was the file transferred?
Which phone ?
That file cannot be fixed. Do you still have a good copy on the phone ? -
This looks like rolling shutter.
You can try video stabilizing software but i don't think its gonna do much. -
That's not rolling shutter. This was obviously shot in a noisy environment. Loud noise, especially with low frequencies in it can upset a cameras sensor and electronics by making them vibrate. This is sometimes made worse if using image stabilization when shooting. Not a lot you can do in these situations except isolating the camera from the noise.
Canon C100 mk2 - Dell XPS8700 i7 - Win 10 - 24gb RAM - GTX 1060/6GB - DaVinci Resolve Studio 18.6.3 - Blackmagic Speed Editor - Presonus Faderport 1 - 3 calibrated screens -
Hey there,
I had the same problem with some videos that i shot. I also tried video stabilizing softwares but unfortunately, it did not work. I guess it´s like @ChapmanDolly said, the loud noises are the problem. So from my knowledge, you cannot really do anything about it.
But maybe somebody else has a solution for this... would be great!
Looks like rolling shutter in response to some kind of regular pulse in your power washer. Not much you can do to fix it other than reshoot with the camera mounted somewhere else.
That said, it's kind of cool.
Remove hdr without converting. Just remove hdr from mkv files
By fits79 in forum Video ConversionReplies: 9Last Post: 12th Jun 2020, 12:02 -
What is this, and can I remove it?
By sventamyra in forum RestorationReplies: 20Last Post: 25th Feb 2018, 11:38 -
Need Help Batch Remove Audio,Remove Subtitle,Change Default Audio and Sub
By Inoyama in forum Newbie / General discussionsReplies: 9Last Post: 9th Jan 2018, 15:20 -
Remove grain?
By bagmand in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Oct 2017, 07:00 -
Need to remove blocks
By kalemvar1 in forum Video ConversionReplies: 2Last Post: 22nd Sep 2017, 13:47
