whenever i edit video with default preset of 720p in any video editing program and the setting of downloaded video link below
[Attachment 53771 - Click to enlarge]
the quality difference is huge.
eg. 720p @1500kbps looks good but when i video convert or edit it looks soo bad.
please explain
Results 1 to 9 of 9
Use a good codec and good settings. Reduce noise and motion in your source. Encode cartoons rather than real video.
You always lose quality when re-encoding with a lossy format. Use a higher bitrate or better settings
There might be other problems - maybe you didn't set up the editing program correctly. Maybe you are inadvertently deinterlacing or resizing. Post more information if you want more help -
Yes.
Not all AVC encoders are created equal. If you use a bad one you may get bad results. If you use a good one you will get better results.
Even if you are using the same AVC encoder you won't get as good results if you use poor settings. For example, x264 at the veryfast preset will not deliver as good quality as x264 at the veryslow preset.
Noise is the enemy of compression. Reduce noise in your source and you will get better compression. Lots of motion is also difficult to compress. Don't expect your shaky, noisy, handheld VHS camcorder video to compress as well as computer generated pie charts.
In general, cartoons compress much better than live action. Cartoons have many duplicate frames (which compress down to nearly nothing) and large flat shaded areas (which also compress very well).Last edited by jagabo; 13th Jun 2020 at 13:25.
720p at 1500kbps is always going to look lousy. That bitrate is just too low to hold detail in the picture. What is your source footage resolution and bitrate? If it is 1080p and has a decent bitrate, you want to keep it at that.
For example, I shoot 1080p at 35000kbps and never reduce the resolution or bitrate below those. The higher the bitrate, the better the quality.Canon C100 mk2 - Dell XPS8700 i7 - Win 10 - 24gb RAM - GTX 1060/6GB - DaVinci Resolve Studio 18.6.3 - Blackmagic Speed Editor - Presonus Faderport 1 - 3 calibrated screens -
man thats the question, i have seen a lot of videos with such a low bitrate and yet it looks soo good, clear sharp.
720p at 1500kbps looks 4k (h264)
but dont know how they do it which software no idea.
One expert please explain this to me....
By Shepherd81 in forum Video ConversionReplies: 14Last Post: 2nd Jun 2021, 15:34 -
Can someone look at this ffmpeg error when downloading video and explain
By jimdagys in forum Video Streaming DownloadingReplies: 2Last Post: 6th Dec 2018, 00:06 -
Can someone explain to me how to do this effect???
By brandon_768 in forum EditingReplies: 7Last Post: 17th Sep 2016, 07:56 -
Someone Explain Deinterlace , Decomb and Denoise.. ??
By FurqanHanif in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jul 2016, 14:57 -
Can someone explain how to edit videos like these?
By TeddyBrosevelt in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2016, 05:28
