  1. I have downloaded some .ts (x264) files which have commercials embedded at a different resolution to the content which I'd like to edit out.
    I'm happy to do this manually as there's only a few commercials, but the problem I'm having is the all the editing software I've tried can't seem to handle a video with different resolutions and locked up or crashes.
    Is there any lossless editing software available (free or paid) which can losslessly edit a video (.ts) with different resolutions?
    Thanks in advance
  2. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Yeah, get the Videoredo trial.
    Aug 2006
    If the files are H.264, you'll need VideoReDo TV Suite rather than VideoReDo Plus.
    I use VideoReDo TV Suite to edit recorded TV. Unfortunately, I can't tell you if it will work for your file or not because I have not yet encountered any recordings with video at more than one resolution.
    If VideoReDo doesn't work, I have no alternatives to suggest. I haven't heard of any video editing software that doesn't choke on video files where the resolution varies.
  4. Originally Posted by usually_quiet View Post
    Thanks for all the reply's,
    I tried VideoReDo and it choked on the different screen resolutions,
    Not sure what to do..
    I'm certain that there is some kind of software that can achieve this as I've seen files from the same station with commercials removed, unless the ad removal process is done at the download stage?
  5. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
