I have been editing my videos for quite some time now by demuxing, working on the audio seperately, sometimes working on the video seperately, and then muxing everything back. Sometimes, after muxing, I work on the video but anyways...
What I am looking for and wondering if it is available, whether free or paid, is a video editor that will let me work on the video AND the audio individually but within the same window or program. All of my work on audio involves simply mute audio segments of the track. Most of my work on video involves trimming or cutting out certain segments of the video and some mosaic/mask effects.
I've searched online but since my needs are so simple I don't really see those in the "features" of said programs or they don't work with the MKV container or they don't support H.265. Ugh. I work with MP4 and MKV containers and only encode using h265 with 10bit HDR. Was wondering if anyone here had a recommendation.
	My NLE, Vegas, shows both the audio and video track at the same time. You can cut the audio at separate places from the video; you can take each of those cuts and apply whatever sound modification you want; and then you can do the same thing for the video. You then render out the result, and Vegas recombines the audio and the video.
 I think pretty much any other NLE can do the same thing.
 But, I may not be understanding your question ...
	I think you understood. I basically just want to be able to work with audio and video within the same editing window or at least the same program. I was hoping to just be able to say... mute an audio segment (which is what I do 95% of the time) in the audio stream without having to cut it and work on it separately.
 I dont think all NLEs can do the same as the program you recommended as I have worked with TMPGEnc 7 and you can't work with the audio alone. I have also tried Filmora from Wondershare and that has the previously mentioned features but, it does not support H.265 which I need.
 I welcome other suggestions.
	What's wrong with Vegas? If you don't want to buy the professional version, they have an entry-level version for very little money that will do exactly what you want. You can download the trial and test it out for yourself.
 https://www.vegascreativesoftware.com/us/vegas-movie-studio/
	I just understood from what you said that I would have to cut the video and audio out of the main video and work on them separately. Maybe I misunderstood. Regardless, I can't get Vegas 17 Pro to work on my PC for whatever reason. It is really slow to load up 4k h265 files and forget about even editing them. Not sure what to do so I am currently still sticking to my tried and true method of demuxing, working on audio seperately, muxing back then working on video.
  Muxing two MP4By justarish in forum Video ConversionReplies: 1Last Post: 8th May 2019, 08:30
  Muxing MP4By nicksteel in forum Video ConversionReplies: 5Last Post: 12th Apr 2019, 14:15
  How to demux avi?By desertcoyote in forum AudioReplies: 12Last Post: 26th Jul 2018, 02:38
  TS folder needs a demux allBy loninappleton in forum Newbie / General discussionsReplies: 35Last Post: 11th Dec 2016, 17:25
  Muxing, can't sync trackBy Azubro in forum Newbie / General discussionsReplies: 13Last Post: 20th May 2016, 23:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
