Background:
I'm trying to find out why HDR10 media on Amazon Prime Video (through the TV app) looks washed out on my LG TV,
has very bright highlights, but shadow detail is in the mid-grey range. The colors are also off, some shows looking
like saturated pastel shades. (Their new show "Upload" is one of the worst).
Yet, YouTube Demos and other sample files I've found on the net, both HDR10 and HDR10+ look
great.
I've been asking on the LG and Amazon forums if anybody has any idea, but so far no response, accept
somebody mentioned it sounds like a tone mapping problem. This seems reasonable, but what does it mean ?
Something wrong in the metadata? (particularly in light of what I found)
I recently got lucky and found something that may help solve the problem - If I knew what I was looking for!
I searched the internet for further HDR samples and I finally found one that exhibits this same washed out look -
but now I can see the file specs.
Just out of interest I re-encoded it in Vidcoder using HEVC/Main10 and this file looks normal on my TV, HDR,
proper color and good brightness range. (To my mind this adds credence to my metadata theory)
Here's the mediainfo of the re-encode and the source, I can provide file samples if anybody would
like to to see them.
My re-encode (720p)
Original file: (4k)Code:General Complete name : C:\Users\davex\Desktop\DEMO-720p.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (isom/iso2/mp41) File size : 6.26 MiB Duration : 59 s 310 ms Overall bit rate : 886 kb/s Encoded date : UTC 2020-06-10 20:58:13 Tagged date : UTC 2020-06-10 20:58:13 Writing application : HandBrake 20200605160604-75bae14a8-master 2020060501 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4@High Codec ID : hvc1 Codec ID/Info : High Efficiency Video Coding Duration : 59 s 310 ms Bit rate : 882 kb/s Width : 1 280 pixels Height : 536 pixels Display aspect ratio : 2.40:1 Frame rate mode : Variable Frame rate : 23.976 (24000/1001) FPS Minimum frame rate : 23.974 FPS Maximum frame rate : 23.981 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.054 Stream size : 6.24 MiB (100%) Writing library : x265 3.2.1+1-b5c86a64bbbe:[Windows][GCC 9.2.0][64 bit] 10bit Encoding settings : cpuid=1064959 / frame-threads=2 / numa-pools=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1280x536 / interlace=0 / total-frames=0 / level-idc=40 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=0 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=30000 / vbv-bufsize=30000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 Encoded date : UTC 2020-06-10 20:58:13 Tagged date : UTC 2020-06-10 20:58:13 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Codec configuration box : hvcC
Code:General Unique ID : 280667973729367058982597086729421534019 (0xD326AF7D29C2EC532F16E12DC81D3343) Complete name : C:\Users\davex\Desktop\DEMO.mkv Format : Matroska Format version : Version 4 File size : 88.0 MiB Duration : 59 s 407 ms Overall bit rate : 12.4 Mb/s Writing application : Lavf58.20.100 Writing library : Lavf58.20.100 ErrorDetectionType : Per level 1 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High Codec ID : V_MPEGH/ISO/HEVC Duration : 59 s 310 ms Bit rate : 12.2 Mb/s Width : 3 840 pixels Height : 1 608 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.082 Stream size : 86.1 MiB (98%) Writing library : x265 3.2+15-04db2bfee5d6:[Windows][GCC 6.3.0][64 bit] 10bit Encoding settings : cpuid=1176575 / frame-threads=5 / numa-pools=36 / wpp / pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1608 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=11 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=40 / lookahead-slices=0 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=3 / tu-intra-depth=3 / limit-tu=4 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=4 / limit-refs=1 / limit-modes / me=3 / subme=4 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=6 / selective-sao=0 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.2 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.30 / pbratio=1.20 / aq-mode=3 / aq-strength=0.70 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qp Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant
New PC, pls recommend me a media player etc to test 4k/hdr playback
By hydra3333 in forum Software PlayingReplies: 78Last Post: 8th Oct 2020, 22:05 -
MPC-BE HDR media in non HDR screens. Oversaturated picture.
By Zapa in forum Software PlayingReplies: 4Last Post: 29th Dec 2019, 12:31 -
4K x265 remove HDR but, keep HDR settings as a backup.
By Someonecool in forum Video ConversionReplies: 4Last Post: 22nd Oct 2018, 23:04 -
HEVC HDR to x264 non-hdr
By mmace in forum Video ConversionReplies: 3Last Post: 20th Nov 2017, 11:19 -
If do not watch 4k hdr content, is it still worth buying a 4k hdr display o
By Stealth3si in forum Media Center PC / MediaCentersReplies: 5Last Post: 19th Sep 2016, 21:03
