I've downloaded this movie hoping that this version will be better than the one I already had (the older version is ok but lower resolution). unfortunately, This version has a noise entire length of the movie. is it possible to remove this by re-encoding ? Any help would be nice
This is how the video looks
[Attachment 53725 - Click to enlarge]
[Attachment 53726 - Click to enlarge]
[Attachment 53727 - Click to enlarge]
Media Info if that helps
General
Unique ID : 187957146777423956541581954681381037346 (0x8D673ACF318CE1488D629772D5EBA522)
Complete name : Final Fantasy 1 The Spirits Within 2001 1080p BluRay DTS x264.mkv
Format : Matroska
Format version : Version 2
File size : 10.1 GiB
Duration : 1 h 45 min
Overall bit rate : 13.7 Mb/s
Encoded date : UTC 2012-06-02 13:54:28
Writing application : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 12.2 Mb/s
Width : 1 920 pixels
Height : 1 036 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.255
Stream size : 8.81 GiB (87%)
Writing library : x264 core 120 r2146 bcd41db
Encoding settings : cabac=1 / ref=4 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=0 / bitrate=12180 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=40000 / nal_hrd=none / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80 / zones=142296,152378,q=31,deblock=1:2
Default : Yes
Forced : No
Duration_Source : General_Duration
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 510 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.12 GiB (11%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Dutch
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:10:02.101 : en:00:10:02.101
00:13:08.746 : en:00:13:08.746
00:17:28.381 : en:00:17:28.381
00:21:06.682 : en:00:21:06.682
00:27:43.078 : en:00:27:43.078
00:34:57.178 : en:00:34:57.178
00:41:22.271 : en:00:41:22.271
00:46:38.045 : en:00:46:38.045
00:52:41.909 : en:00:52:41.909
00:58:09.444 : en:00:58:09.444
01:03:28.722 : en:01:03:28.722
01:13:36.329 : en:01:13:36.329
01:18:43.260 : en:01:18:43.260
01:23:36.094 : en:01:23:36.094
01:30:28.465 : en:01:30:28.465
Closed Thread
Need help removing A/C noise from presentation
By moxiecat in forum AudioReplies: 11Last Post: 26th Sep 2019, 07:12 -
Audio Restoration: Removing noise and hum
By mfransen in forum RestorationReplies: 8Last Post: 25th Oct 2017, 06:15 -
Removing Wind Noise ?
By blewyn in forum RestorationReplies: 6Last Post: 1st Jul 2017, 11:11 -
removing noise from anime/cartoon
By ThePi7on in forum RestorationReplies: 16Last Post: 13th Jan 2017, 14:18 -
ffmpeg noise filter usage based on mplayer noise settings?
By Selur in forum Video ConversionReplies: 5Last Post: 21st Jun 2015, 08:19
