.mp4 plays audio only...sux.I am hoping you can help.
Started with .mov file made with iMovie. Here is the media info
When coverting to mp4 using ffmpeg, the resulting file will not play in quicktime or in a Firefox. It does, however, play in vlc on mac.
Here is the ffmepg command used:
Media info for .mp4 fileHTML Code:ffmpeg -i stats_on_police.mov -vcodec h264 -acodec aac stats_on_police.mp4
The videoless mp4 is at this link: https://legacy-systems.biz/longview2500/topics/2020_race_riots/stats_on_genocide/img/s..._on_police.mp4
Last edited by carlarogers; 8th Jun 2020 at 10:33. Reason: Corrected the ffmpeg command used.
Strange. You used the parameter -vcodec copy, but ffmpeg converted from ProRes to AVC anyway. Same for the audio: PCM to AAC, despite -acodec copy. I doubt you told us the correct parameters.
The reason why the video is not visible is probably that it was encoded in High Profile 4:2:2, but most media players only support a 4:2:0 AVC profile (Main or High). -
The video is 10 bit AVC and uses 4:2:2 chroma subsampling. Both of those can be problematic for some players.
Add -vf "format=yuv420p" to your command line after the input file spec.
Code:ffmpeg -i stats_on_police.mov -vf "format=yuv420p" -vcodec h264 -acodec aac stats_on_police.mp4
FFMPEG Conversion from MKV to MP4 returns a empty MP4 file?
By lolmaisine in forum Video ConversionReplies: 4Last Post: 6th Mar 2019, 08:45 -
Split mp4 file into specified size (part1.mp4, part2.mp4 etc.)
By TubeBar in forum EditingReplies: 7Last Post: 1st Feb 2019, 23:41 -
how can i join two videos a1.mp4 + a2.mp4 = a12.mp4
By sommers in forum Newbie / General discussionsReplies: 14Last Post: 8th Jun 2017, 19:01 -
What display was std def 16:9 intended for?
By brassplyer in forum DVB / IPTVReplies: 21Last Post: 1st Jan 2016, 16:19 -
Homemade mp4 files quality vs. ripped movies in mp4 format
By MrMX in forum Newbie / General discussionsReplies: 11Last Post: 26th Nov 2015, 23:12
