I just picked up a DVD burner and am starting out in the world of DVD creation. I have created a couple of DVD-R and -RW disks from old hi8 home movies that I have and I am pretty happy with the results. My question is this. Is it possible to do a diskcopy of a DVD-R or DVD-RW to another DVD-R or DVD-RW (like CD-R to CD-R)? If so, what is the best software to use? I understand it is possible to rip the info off the DVD and then burn it to another DVD, but I just want to copy one disk to another without all the ripping or reauthoring. I only wish to make copies of my own DVDs that I have created on my burner (Pioneer 104) so I don't believe there is any encryption element involved. Can anyone shed some light on this for me?
SPMC
only problem i can see youll have from the get go is that if you try to disk copy a DVD to DVDr is that the source is around 9 gigs (double layer) and dvdr media is only 4+ gigs (single layer). so you wont have room.
use dvd decrypter, it has option to rip DVD to image, then just burn it back to DVD-R with dvd decrypter or any other tool
To answer your question, Yes, a DVD-DVD copy is possible (I do it all the time). I use NERO 5.5.8.0.
Yes, that version of Nero does a great job.
I just got the new Pioneer set top DVD recorder and tried to make copies of a disc using Prassi (comes with the Pioneer A-03 computer DVD burner), and if failed.
Using Nero to create an image, I'm able to make as many copies of that disc as I want. -
Okay, thanks for the quick replies. SLK001 I think you are on to what I am asking about. I only want to diskcopy DVD-R or -RW disks that I have edited and authored myself. It is already on 4.7gb media and only contains about 3-4gb of video. It seems to me it would be easier to just do a diskcopy, if possible, rather than rip and burn or image to disk and burn or reauthor and burn.
What is the best way to get Nero 5.5.8.0? I have never used Nero, is it real straightforward and easy to use? I am new to this stuff and a slow learner to boot.
SPMC -
Go to EBay and search for NERO. You can get a full version for less than $20. You can also download 5580 as a trial from:
http://www.nero.com/
You'll get full useage for about 30 days (buy it to get a serial number to continue use). I've used many different burner softwares... NERO tops them all - hands down!
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
