I recently noticed that a number of Verbatim #47512 1TB USB 2.0 3.5" desktop external hard drives that I use, occasionally disconnect under Windows 7 64-bit when performing reading or writing operations. When this happen the hard drives remain visible to Windows, but their contents are not visible. I originally suspected the drives as failing, but these work fine when connected directly to the motherboard. I now suspect that the problem is related to CrystalDiskInfo. I am using the latest (8.5.2) 64-bit version and I found that if CrystalDiskInfo is not loaded, the problem does not seem to happen. Has anyone come across to a similar problem?
More likely that the cheap USB interface and/or the cheap power supply is failing.
Possible since USB 2.0 drives must be fairly old.
Also possible that the USB port/ports are going bad. When testing different USB ports, don't use ports next to each other as they be bridged internally causing the same issue.
However since you say it doesn't happen when Crystaldiskinfo isn't running, it may well be the program that's the issue. The solution may be not to run the program, which should have to be kept active unless you want to check the disk, which should only be run to take a snapshot of the drive's status. .
Which external hard drives work best with iMac 2019?
By r3drokz in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2019, 14:57 -
what do you call external usb drives that are not flash drives?
By oduodui in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2019, 13:21 -
copy spanning to external hard drives
By victoriabears in forum ComputerReplies: 13Last Post: 8th Aug 2017, 06:49 -
Any good USB External DVD Drives that upconvert on playback?
By ahhaa in forum ComputerReplies: 17Last Post: 17th Apr 2016, 11:41 -
How to get external hard drives to sleep...
By siratfus in forum ComputerReplies: 6Last Post: 16th Jun 2015, 20:18
