I use MeGui to encode my files, this time Video and Audio are out of sync!
Source is a WEB-DL MKV files with E-AC-3 audio
This is the source INFO:
Audio
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Format profile : E-AC-3+Atmos / E-AC-3
Codec ID : A_EAC3
Duration : 1 h 4 min
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 15 objects / 6 channels
Channel positions : 15 objects / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 352 MiB (14%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
This encoded INFO:
Audio
Format : AAC
Format profile : HE-AAC / LC
Format settings : Explicit
Codec ID : A_AAC-2
Bit rate : 185 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz / 24.0 kHz
Frame rate : 23.438 FPS (1024 SPF)
Delay relative to video : 31 ms
Stream size : 84.6 MiB (12%)
Language : English
Default : Yes
Forced : No
assuming the input if not out of sync, it's probably either:
a. that the input is VFR and your settings do not respect that while using MeGui (in case this is possible in MeGui).
b. that your input is broken one way or the otherusers currently on my ignore list: deadrats, Stears555, marcorocchini
DV File Audio Video Sync Issues - Audio Drift
By Christina in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 2nd Mar 2020, 07:58 -
Audio sync problem — video goes out of sync after a while
By maxalfreeman in forum AudioReplies: 4Last Post: 12th Sep 2019, 14:07 -
Video and Audio of out sync
By videohelpuser in forum AudioReplies: 2Last Post: 23rd Apr 2017, 21:15 -
Random audio/video sync problem with webcam recorded video
By TinoArts in forum Video ConversionReplies: 2Last Post: 3rd Aug 2016, 13:57 -
VirtualDub audio out of sync, other video players all in sync
By a1s2d3f4 in forum Newbie / General discussionsReplies: 7Last Post: 11th Apr 2016, 22:36
