  1. So I'm enjoying my card but I'm really disliking the software. The problem is that the only file format options I'm given are AVI YUV/RGB, AVI Motion JPG and Quicktime Uncompressed. Unfortunately, NONE of the many hard drives that I have can keep up with the uncompressed formats and Motion JPG is my only option.
    I tried OBS studio but it doesn't let you capture uncompressed sound.
    Are there any other suggested options?
    Jan 2016
    How do you expect people to suggest software when no one knows what kind of videos you are capturing, SD, HD, what Format....?
  3. Originally Posted by dellsam34 View Post
    Well, you can also ask that question without coming across like...you are.
    HD. 1080p 23.976 And I'm looking for any HQ format that most hard drives can handle.
  4. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    Which capture device do you use ? that's more important, which OS ? these important things you still need to mention.
    my "guess" is that you're on windows, and then you should try to install the AVID codecs, these codecs compress (intra frame wise) your hard drives should keep up that way, if you're on MAC you could use the equivalent Prores codecs. my guess is you use a BlackMagic Design device.... card or Shuttle ?
  5. Originally Posted by Eric-jan View Post
    I am on Windows and I'm using the BM Decklink Mini recorder.
    I've tried every hard drive I had and none of them were able to completely keep up for some reason. All USB 3+
    Also, how do you get BME to use other codecs?
  6. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    Your Decklink Mini Recorder will support these codecs according to the BMD specs sheet:
    AVC-Intra, AVCHD, Canon XF MPEG2,
    Digital SLR, DV-NTSC, DV-PAL,
    DVCPRO50, DVCPROHD, DPX, HDV,
    XDCAM EX, XDCAM HD, XDCAM
    HD422, DNxHR & DNxHD
    ,Apple
    ProRes 4444, Apple ProRes 422 HQ,
    Apple ProRes 422, Apple ProRes LT,
    Apple ProRes 422 Proxy,
    Uncompressed 8-bit 4:2:2,
    Uncompressed 10-bit 4:2:2.
    The linked ones are the Avid codecs, you should ask your questions on the BlackMagic Design forum for this.
    It comes down to installing the codec(s) according to the 3rd party specs, you can't add codecs with BME.
    after installing the codecs, you should re-install Desktop Video Setup.
  7. Originally Posted by Eric-jan View Post
    I installed them and they're not showing up.
    I also posted on the forum. No responses.
