Hi.
Is there any way to simply remove hdr from any mkv file without re-converting?
Just like we remove the dts-hd and get only the dts core from any mkv file with mkvtoolnix.
Is there any way to do it with any program?
Results 1 to 10 of 10
So with little words i can't simply remove hdr from a mkv without recoding all the file?
Assuming we are talking about hdr-10 or hdr-10+ it should be possible to remove the hdr meta data, but your video would have 'dull' colors which would look way different than the hdr data.
It would be the same as watching a hdr movie on a non-hdr display which does not hdr->sdr color adjustments (= tone mapping).
https://www.mysterybox.us/blog/2016/10/27/hdr-video-part-5-grading-mastering-and-delivering-hdr has some nice screen shots like:
left one is HDR content on SDR display without tone mapping, the two on the right basically show different tone mapping methods applied.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
So even i remove the hdr if i don't do the tone remapping the video shows as it is the left picture.
Correct? -
Yes, the one on the left is what a hdr10/hdr10+/doblyvision video looks like without the hdr data.So even i remove the hdr if i don't do the tone remapping the video shows as it is the left picture.
Correct?
So without reencoding, removing the hdr data is usually not what you would aim for.
MPC-BE HDR media in non HDR screens. Oversaturated picture.
By Zapa in forum Software PlayingReplies: 4Last Post: 29th Dec 2019, 12:31 -
4K x265 remove HDR but, keep HDR settings as a backup.
By Someonecool in forum Video ConversionReplies: 4Last Post: 22nd Oct 2018, 23:04 -
"Restore SDR" or "Remove HDR" its possible?
By danfgtn in forum Newbie / General discussionsReplies: 7Last Post: 7th Jul 2018, 16:33 -
HEVC HDR to x264 non-hdr
By mmace in forum Video ConversionReplies: 3Last Post: 20th Nov 2017, 11:19 -
If do not watch 4k hdr content, is it still worth buying a 4k hdr display o
By Stealth3si in forum Media Center PC / MediaCentersReplies: 5Last Post: 19th Sep 2016, 21:03
