I have lots of videos from a Samsung camcorder in .mov that playback choppy and stuttering. I have tried converting to MP4 with same problem.
I don't know what the problem is so don't know how to fit them. Please use layman language in your response. My video knowledge is basic.
				Results 1 to 18 of 18
	There's definitely a lot of frames out of sequence. An sample of the original (not reencoded) would be best.
	Yes @poisondeathray, the originals play in the same way.
 The movie files are saved on a cloud service, Amazon Drive, and automatically convert when I download them. The original is a .mov and you should be able to view it from the link below.
 Take a look at the photos I shared from Amazon Photos: https://www.amazon.com.au/photos/share/YFmSGPzIbjm34VSwBF7IcloaejbwtOIcNKeLamgyQj3
	There's a download link on that page that gives a 42 MB mov file encoded with Apple Intermediate Codec. That's different than the "Converted" video which is encoded with Prores. But the sequence of the frames is exactly the same. I was able to analyze the clip and found that one frame out of every 6 was out of sequence. Unfortunately, the cadence changes several times. But here's an AviSynth script that puts them in the correct order:
 LSmashAudioSource() didn't work right for the audio so I muxed the original audio along with the new video.Code:src = LSmashVideoSource("C:\Users\John\Downloads\clip-2016-05-01 13;41;22.mov") p1 = src.Trim(0,1) p2 = src.Trim(2, 117).SelectEvery(6, 1,2,3,4,5,0).Trim(0,115) p3 = src.Trim(118, 233).SelectEvery(6, 1,2,3,4,5,0).Trim(0,114) p4 = src.Trim(234,349).SelectEvery(6, 1,2,3,4,5,0).Trim(0,116) p5 = src.Trim(350,0).SelectEvery(6, 1,2,3,4,5,0).Trim(0,30) p1++p2++p3++p4++p5
	Oh, there's another solution: discard all the odd numbered frames.
 That gives a 25 fps video. The original video is 50 fps but every frame has a duplicate. So you don't really lose anything by discarding half of them.Code:LSmashVideoSource("C:\Users\John\Downloads\clip-2016-05-01 13;41;22.mov") SelectOdd()
	Thank you jagabo. It makes me really happy to know there is a solution. I have 236 movies like this. Can I use that AviSynth script and apply it to all of them at once? Or apply the second solution of deleting the odd numbered frames all at once, or will I have to go into each one and edit it? I haven't edited before. Which software is best to analyse them - and compatible to MacOS?
 AIC (Apple Intermediate Codec) and Prores are video formats and types of compression. Consumer level cameras typically do not record directly to those formats
 When you have a camcorder, most Mac software like imovie does not ingest things like AVCHD natively; they convert to one of those intermediate formats for editing
 So it's unlikely that the original camera files were like that - and it's probably an issue with the conversion somewhere
 Also notice the resolution is 960x540 , again, unlikely that the camera recorded like that
 To drop half the frames, one way is to use ffmpeg . It's command line driven and you would need to open a terminal . But that would make it possible to batch convert them . I don't know the syntax for ffmpeg batching on a mac.
 I'm not sure if selur's hybrid can do it, it might be able to and runs crossplatform including osx
 https://www.videohelp.com/software/Hybrid
 This is what the ffmpeg command would look like for 1 file
 Code:ffmpeg -i "clip-2016-05-01 13;41;22 (Converted).mov" -map 0:0 -map 0:1 -map 0:2 -vf "select='mod(n, 2)',fps=25,format=yuv420p" -c:v libx264 -crf 20 -c:a copy output.mov
	I'm not sure keeping only odd frames will work for all the videos though. Some might need to keep only even frames. Some might require an adaptive algorithm. Poisondeathray's ffmpeg command line modified to keep even frames:
 Code:ffmpeg -i "clip-2016-05-01 13;41;22 (Converted).mov" -map 0:0 -map 0:1 -map 0:2 -vf "select='mod(n, 2)-1',fps=25,format=yuv420p" -c:v libx264 -crf 20 -c:a copy output.mov
	Thank you. Taking a step back - how do I view my videos frame by frame to work out which frames are out of sync or the odds (or evens) are duplicate frames. I have tried looking on iMovie and can move frame by frame with an arrow key but I can’t see any info associated with each frame so can’t tell which is in the wrong order.
	The old Quicktime Player 7 can display frame number, just click on the left bottom corner where the time is displayed and select "frame number"
 https://support.apple.com/kb/DL923
	The old version 7 does - you can toggle the frame number display or time display;
 I have the Windows version of QT player 7 and it does too
	Another way you can preview is to use ffplay to preview using one version of the filter.
 orCode:ffplay -i "clip-2016-05-01 13;41;22 (Converted).mov" -vf "select='mod(n, 2)',fps=25,format=yuv420p"
 But - if both are jerky with simple even or odd selection sets - then you probably have other problems with that video and would need to try other methodsCode:ffplay -i "clip-2016-05-01 13;41;22 (Converted).mov" -vf "select='mod(n, 2)-1',fps=25,format=yuv420p"
 There should be a way to make a droplet for ffplay or ffmpeg scripts for easier use, but I mainly use windows, not sure how to do it
  Stuttering/choppy playback of high bitrate videosBy aussie43 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jan 2020, 22:41
  [MPC-HC] Increasing/Decreasing playback speed causes choppy videoBy Zee530 in forum Software PlayingReplies: 6Last Post: 16th Jul 2019, 11:57
  can't fix choppy/stuttering Video PlaybackBy Gwar in forum Software PlayingReplies: 11Last Post: 8th Feb 2019, 19:47
  4x2 video wall - ffmpeg / vlc playbackBy lootssl in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2018, 20:00
  H.265 (HVEC) Poor/choppy video playback - FAST LaptopBy MrCrazyJOEMAN in forum Software PlayingReplies: 9Last Post: 14th Sep 2016, 18:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
