  1. Hello!
    I am trying to generate a raw video stream with luma only (monochrome, YUV400) 8bit pixel data using the following command:
    ffmpeg -i input.mp4 -vcodec rawvideo -pix_fmt raw.yuv
    I also tried to use the following filter to extract only the luma channel. The end result was the same.
    ffmpeg -i input.mp4 -vcodec rawvideo -pix_fmt gray -filter_complex 'extractplanes=y[y]' -map '[y]' raw.yuv
    After that I tried to h.264 encode the raw stream with the profiles that support monochrome pixel data (eg: high)
    ffmpeg -f rawvideo -vcodec rawvideo -pix_fmt gray -s 640x512 -r 60 -i raw.yuv -codec:v libx264 -profile:v high -c:a copy out.mp4
    However, I always get the following error, which indicates that the raw stream is not in the monochrome format that I would have expected:
    x264 [error]: high profile doesn't support 4:4:4
    I am new to ffmpeg and video formats in general. Can somebody please point out what I am missing?
    Thank you!
    Aug 2013
    Central Germany
    On one hand, you may omit -profile:v high if you don't need it with a good reason, giving x264 a chance to automatically select the required option.
    On the other, you may be able to tweak the expectations of the x264 encoder with parameters like input-csp / output-csp if it was a separate encoder, but I am not sure how to handle that with x264 as an encoder library inside ffmpeg, sorry... maybe any other user here is more knowledgeable in this topic.
    As you apparently have a raw YUV source, I would recommend using x264 separately here, without ffmpeg wrapped around.
    One more suggestion: Instead of creating a headerless YUV file, try Y4M (YUV4MPEG), its header contains the video frame dimensions and the pixel format identifier, so you can care less about a few parameters.
  3. First of all, thank you very much for your quick reply.
    Regarding the -profile:v high parameter. I need to compare the performance of a software and hardware codec. Both need to run with the same profile.
    Thank you for your hint regarding the input-csp / output-csp options. I will look into that.
  4. Your ffmpeg command lines worked for me. Starting with an AviSynth script that created a short 640x512 YV12 video:
    ColorBars(width=640, height=512, pixel_type="YV12")
    Trim(0,99)
    saving as raw Y8:
    ffmpeg -y -i cb.avs -vcodec rawvideo -pix_fmt gray raw.yuv
    then:
    ffmpeg -y -f rawvideo -vcodec rawvideo -pix_fmt gray -s 640x512 -r 60 -i raw.yuv -codec:v libx264 -profile:v high -c:a copy out.mp4
    gave:
    General
    Complete name                            : C:\Users\John\Desktop\out.mp4
    Format profile                           : Base Media
    Codec ID                                 : isom (isom/iso2/avc1/mp41)
    File size                                : 5.25 KiB
    Duration                                 : 1 s 667 ms
    Overall bit rate                         : 25.8 kb/s
    Writing application                      : Lavf58.29.100
    Video
    Format profile                           : High@L3.1
    Format settings                          : CABAC / 4 Ref Frames
    Format settings, Reference frames        : 4 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate                                 : 16.1 kb/s
    Width                                    : 640 pixels
    Height                                   : 512 pixels
    Display aspect ratio                     : 5:4
    Frame rate mode                          : Constant
    Frame rate                               : 60.000 FPS
    Color space                              : Y
    Bits/(Pixel*Frame)                       : 0.001
    Stream size                              : 3.27 KiB (62%)
    Writing library                          : x264 core 159
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=0 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=16 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Codec configuration box                  : avcC
  5. Thank you very much!
    I tried it on Windows and it worked fine too.
    Finally figured out that the version installed on linux was quite old (ffmpeg 3.4.7). After installing 4.2.3 everything worked fine
