Hello there!
I actually downloaded a video from twitch using the "youtube-dl" tool.The video is 30+ hours long,but it shows me only 4:30 h. in the seeker.By seeing the actual size of the file on the disk of nearly 50gb i though about there's a problem in "coding" if could be said that way.Also after~ 03:53:00 ~ when i try to seek it throws me at the very last part of the original 30h+ content. So I managed to figure out by seeking trough the available points of the video that somehow if I let it continue without seeking after ~ 03:53:00 ~ it doesn't finish at 04:34:00 as it is showed in the player and it continues like if its working normally,but without the ability to seek. I'm using (happened to all the players i tried) currently kmplayer.I'm really confused about what to do now and how to ask questions about that.Is there any way to add the original length information inside the video file ?Would be very grateful if somebody got a solution.
Thanks in advance !
(edited)
the file is .mp4 format , not ,mkv , and as i see that this software is mkv retaliated
Seeking to improve video quality
By jarod1005 in forum Newbie / General discussionsReplies: 45Last Post: 12th Apr 2019, 11:31 -
inconsistant video seeking from OBS studio records
By Golem in forum Newbie / General discussionsReplies: 16Last Post: 10th Apr 2019, 11:33 -
17 GB HQX (AVI) video file freezing VirtualDub when seeking
By kingmustard123 in forum Capturing and VCRReplies: 5Last Post: 15th Aug 2017, 15:57 -
Seeking/jumping forward/backward in a video
By [ss]vegeta in forum Software PlayingReplies: 8Last Post: 6th Aug 2017, 10:21 -
VOB file(s) showing 24 hour length!! How to fix
By chillcat34433 in forum Video ConversionReplies: 5Last Post: 18th May 2017, 13:13
