Hey there! My problem is pretty simple. I can't move subtitles vertically in potplayer. However, I can move them horizontally.
Until now I've tried the following:
Pressing alt+down arrow all the way up to 100% and way back to 0%
Pressing down in control pannel all the way up to 100% and way back to 0%
Changing the vertical position percentage in font style
It seems to me it may be a problem related to the file I'm using. The file is in the srt format. Maybe other files, even with the same format, won't give problems.
EDIT: I even tried the beta and some 2015-2018 versions of the program but to no avail.
				Results 1 to 1 of 1
  PotPlayer not finding all available subtitles using OpenSubtitlesBy bloodhand in forum Software PlayingReplies: 1Last Post: 27th Oct 2021, 20:29
  Potplayer subtitles Not showing questionBy Budman1 in forum SubtitleReplies: 0Last Post: 28th Mar 2020, 02:27
  Potplayer - Disable Subtitles?By vanbrocklin in forum Software PlayingReplies: 2Last Post: 28th Dec 2019, 22:34
  Moving potplayer always shows message: frame capturing saving to clipboard.By bobolinkeuphoric in forum Software PlayingReplies: 0Last Post: 31st Aug 2019, 15:58
  Fixing PotPlayer no subtitles issueBy AlwaysAnonym in forum Software PlayingReplies: 0Last Post: 2nd Jan 2019, 18:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
