Hi,
I am capturing from Hi8 to DVcam via s-video and mini jack audio, then fire-wire to PC Wim 10x641909.
I am not sure what software. I should use.Vd2 or 1.911 or Scenalyzer.
I have tried Scenayzer however I can't get it to capture.
As soon as I press Capture in sclive the DV cam goes into play mode and stops showing the vision from the Hi8.
I am obviously not doing something right. Any help please?
In Options>Misc.Options set "use device control" to NO.
And in Options>Capture Settings you should set "max. file size" to unlimited. -
I am still trying other programs to see if I can get a better result and have Magix Media Edit Pro Premium.
I chose the DV capture and it give a good picture however it stops recording every 20MB or 6 seconds.
I have tried different tapes but still get the same stopping. When I hit the record button again, it stops at 20MB or 6 seconds.
It does not do this is the other programs I have tried and the Magix forum is also baffled. I have checked all options and they are correct.
Does anyone have any inkling what could cause this please?
Help with Hi8 capture
By ozstar100 in forum Capturing and VCRReplies: 2Last Post: 28th May 2020, 05:17 -
best capture card for vhs and hi8 capture
By hdfills in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2018, 12:21 -
Hi8 capture - best quality
By eedwards86 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 19th Apr 2018, 13:44 -
Hi8 Capture Issues
By creaper in forum Capturing and VCRReplies: 5Last Post: 26th Aug 2017, 10:07 -
Hi8 Capture best method
By jtech1 in forum Capturing and VCRReplies: 5Last Post: 10th Mar 2017, 14:25
