Hi
I made a recent post regarding capturing video using an EasyCap and Arcsoft ShowBiz. Im now instead trying to capture using VirtualDub but am unable to see the video being played.
The software is finding the capture unit but when i try to see it being played on the software i cannot see it.
The steps i am doing are:
File>Capture AVI
Device> select the Easy Cap "USB 2861 (Direct Show)"
Video>Preview
Advice on how to rectify appreciated!
Thanks!
Results 1 to 15 of 15
You must also set video > 'Video Source', 'Capture Pin' and 'Capture Filter' - maybe some others but those should give you a picture.
Thanks. I forgot i HAD set the 'video source' but hadnt set the 'Capture Pin' or 'Capture Filter. I will play around with those settings... unless... i dont suppose you know what they need to be?
There are lots of options PAL, NTSC, SECAM and then different versions of those e.g. PAL_M, SECAM_L1 -
Whatever you source material is >> NTSC (US) VHS, PAL I/G (Europe except France) VHS would be a good place to start.
You don't know the standard of you tapes? where do you live and where the tapes originally shot at? Possibly what VCR or camcorder used to make them at the time? the more details you give the better the help you get.
Location?
- North America + Japan = NTSC
- Most of the rest of the world = PAL
It's more complex that that, but it's the quick version. Lots of exceptions, odd formats or SECAM.Want my help? Ask here! (not via PM!)
It should be PAL.
There are various tutorials on how to set up vdub for capturing - I recall posting a link to a quite comprehensive one some weeks ago - so do a forum search.
And also do initially make sure your video source is composite (unless your VCR is S-VHS) -
DB83- Thanks. Ive tried on every PAL setting and used composite (i have a Daewoo-DF4700 machine) but still not able to get a picture.
I searched prior posts and found a thread where youve offered similar advice on settings (https://forum.videohelp.com/threads/396966-8mm-digitalization-Picture-is-either-blinki...ght=virtualdub) but cant find where youve posted a link to vdub capture (i checked back until Jan for threads with Keyword(s): virtualdub; User: DB83)
I have searched you tube for guides and have followed guidance but unfortunately no luck yet! -
You will also note the reference to the 'easycrap' in that post.
But there was another topic which I also can not locate. If memory serves the actual guide was in another forum - possibly Doom9 - quite a few members on here frequent both places. Google led me to a guide on DigitalFaq but that one, apologies to lordsmurf - the boss on there - , seems outdated.
I would also check the Preview settings. At the very least you should have a black square on your screen where the video would go. -
Hi im using Virtualdub too and in Video source is empty space can choose anything
Computer based video capturing involves a lot of hand shaking between capture card/PC, PC/Capture software, Those conflicts are hard to resolve via an online forum. If someone doesn't know how to troubleshoot driver conflicts, capture card settings, registry ...etc on their own the easiest way is to get those cheesy capture devices that capture to an SD card, You wouldn't get any worse quality than what the easycrap can provide anyway.
Picture "squeezed" in Virtualdub
By malling in forum Newbie / General discussionsReplies: 15Last Post: 27th Aug 2019, 20:12 -
(EasyCAP DC60) Audio plays before the video, using VirtualDub
By p0zopa in forum Capturing and VCRReplies: 2Last Post: 13th Dec 2018, 11:40 -
1 picture every X minutes with VirtualDub
By trantsyx in forum Capturing and VCRReplies: 8Last Post: 11th Sep 2018, 07:02 -
EasyCap shows up as OEM Device in VirtualDub - No video signal! How to fix?
By elgy in forum Newbie / General discussionsReplies: 1Last Post: 24th Mar 2017, 10:36 -
ffdshow/virtualdub/avisynth problem: the picture becomes larger than origin
By spiritt in forum Newbie / General discussionsReplies: 3Last Post: 11th Aug 2015, 05:49
