I was looking for users who have or have had/worked with Smart Renderer 5 from Pegasys, but of course any help from anyone would be appreciated. I am having trouble working with 4k video in Smart Renderer 5. I have a decently powered PC and I actually use Tmpgenc Works 7 (also from Pegasys) to edit 4k video with no problems. The problem is my frame rate drops considerable in Smart Renderer 5 to the point I can't work with it. Maybe some users have some suggestions. Thank you.
Results 1 to 9 of 9
'Smart Renderer 5 from Pegasys supported resolutions: 1920x1080 / 1440x1080 / 720x480
https://tmpgenc.pegasys-inc.com/en/product/tmsr5_spec.htmlExtraordinary claims require extraordinary evidence -Carl Sagan -
I'm having no problems with 3840x2160 avc material from a Nikon -- 23.976fps, 12 frame GOP.
How are your files encoded? -
I've used this for years.
But I don't use it for 4K, nor really even HD all that much.
Mostly use it to fix other people's H.264 mistakes, quick edit or audio re-encode.Want my help? Ask here! (not via PM!)
I am guessing when you say boggy you mean the program gets bogged down? Or did you mean buggy? If you meant bogged down by H.265 files, I guess I could try to reencode from H.265 to H.264 and see if that works. My H.265 1080p videos works flawless with Smart Renderer 5.
I'm pretty sure there is a way to go from h.265 to h.264 losslessly using ffmpeg but, someone correct me if I'm wrong. If true, maybe the only downside would only be larger files? -
So I was able to convert from h.265 to H.264 using ffmpeg. I set the constant quality factor to 0 and kept the bitrate same as source. I THINK this gave me a lossless conversion but, the file size only went from 12 gig to 12.2 gig. I thought it would be like 20 times larger. I really see not quality difference whatsoever but I could be wrong.
Of course, now I don't have 10 bit HDR. Its my understanding that H.264 can support 10bit but some adjustments have to be made at the container level?
ABBrittain has tearing issues with MPC Video Renderer
By flashandpan007 in forum Software PlayingReplies: 0Last Post: 13th Jan 2020, 11:45 -
Free software like TmpgEnc Smart Renderer
By adrian44 in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2019, 21:31 -
Smart Renderer 5 Won't Smart Render a Clip
By criggs in forum EditingReplies: 0Last Post: 5th Dec 2016, 11:41 -
Video in .ts extension cannot renderer in players
By imototep in forum Video ConversionReplies: 4Last Post: 8th Jun 2016, 02:13 -
Where to find Haali Renderer?
By Des in forum Newbie / General discussionsReplies: 7Last Post: 21st Oct 2015, 20:35
