Hi, newbie here -
This is going way back, but I used to use a program called DVHSCap to capture lossless footage from my Canon HV20 and it would create a raw file. I've lost the software since then and was wondering if anyone knows if it can still be downloaded anywhere? I've googled for hours but can't seem to find anything (for Mac, that is). Any help would be appreciated!
	bravo1224Guest
	VirtualDVHS is: http://seth.mattinen.org/notes/hdrec.php
 For DVHSCap, you need the Firewire SDK 26 (firewiresdk26.dmg), which is (supposedly) here:
 https://developer.apple.com/downloads/download.action?path=FireWire/firewire_sdk_26_fo...ewiresdk26.dmg
 Perhaps this?
 https://www.cuttingcords.com/s/AVCVideoCap_original.zip
 Or: https://www.cuttingcords.com/s/AVCVideoCap.zipLast edited by lordsmurf; 1st Jun 2020 at 18:48. Want my help? Ask here! (not via PM!)
	bravo1224GuestThanks, lordsmurf! The Firewire SDK 26 doesn't seem to be available anymore but AVCVideoCap seems to be doing the trick. Downloading through firewire to an *.m2t file is probably best way to capture a lossless raw file off a Mini DV camcorder, right? Thanks again!
	Yes, that is the ONLY way to do it. The Firewire on my Sony FX-1 (also an HDV camcorder) blew out, so I tried capturing from the RGB ouptut. However, I soon realized that this involves uncompressing the HDV and then recompressing with the capture card, so I ended up with a new set of compression artifacts.
 So, I spent $450 to have the Firewire repaired.
 One small correction: the HD video on your camcorder is stored as HDV, not DV. The two both get recorded to the same tape cartridge (HDV prefers a more expensive tape formulation, but you can record just fine on standard, older DV tapes). It is important to make this distinction because capture programs like WinDV or Scenalyzer, which were designed for the standard definition DV format, won't capture from an HDV camcorder.
 I use the HDV capture built into Vegas, my NLE. It works great.
	bravo1224GuestJohn - oof, the things we do to get footage off these darn camcorders! Good to know that Scenalyzer won't capture HDV footage as that was going to be my next step, thanks.
	The other thing that convinced me to get the camera repaired is when I used a local guy to do the transfer. He had a transfer business that he had moved from a commercial building to his house. I went there, started the capture, and waited two hours while the tapes played and captured to my laptop.
 However ...
 During that time I watched while a steady stream of people came to the house, not to have their tapes transferred, but to buy dope. The guy's main business was dealing dope!! I'm pretty much a "live and let live" kind of guy when it comes to things like that, but I realized that I probably didn't want to do that every few months. So, since $450 was a lot less than the $3,500 it would cost to get an equivalent camera, I had it fixed.
  Mac to MacBy Aldinho57 in forum ComputerReplies: 2Last Post: 1st Jun 2020, 15:01
  accounting software for Mac bookkeeping software for MacBy Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 14:43
  Hardsub on MacBy Crimson123 in forum SubtitleReplies: 4Last Post: 2nd Oct 2016, 08:52
  Slow MacBy Jeikobu in forum MacReplies: 13Last Post: 17th Mar 2016, 20:37
  Which Mac AdviceBy Joolsd in forum MacReplies: 3Last Post: 22nd Feb 2016, 18:48
 Quote View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
