Hi,
Can anyone tell me the dimensions of the belts for a Sony EVO-9850 Hi-8 deck?
Or direct me to where I can find them?
Where can I buy such belts of good quality at a reasonable price?
many thanks,
Pat
PRB Belts is where I used to get all my belts when I repaired VCRs, tape players etc. Here's a link:
http://russellind.com/client/download/belts.pdf
You can purchase a measuring tool from them so you can measure both the thickness and diameter of your belts. Some belts are round; some are square; and some are flat. You need to determine that before you measure and order. Always order something a little smaller in diameter/length than your old belts because old belts have typically lost their elasticity and have therefore stretched.
You can try Googling your model and include in the search "service manual" OR "repair manual" and you might find an actual service manual which will include the belt specs.
Internal & External Hard drives foe source or Rendered projects
By braveheart3158 in forum Newbie / General discussionsReplies: 2Last Post: 21st Apr 2020, 23:58 -
Sony EVO-250 Hi8 VCR - Dirty heads?
By Vitality in forum RestorationReplies: 16Last Post: 4th Feb 2019, 08:12 -
Sony VO 9850 Broadcast 3/4" Deck- Error 2 Tape Slack
By braxus in forum Off topicReplies: 5Last Post: 9th Jul 2018, 10:08 -
Minimum Computer Specs for VHS Capture & Editing
By TazDave in forum Newbie / General discussionsReplies: 31Last Post: 4th Mar 2017, 00:44 -
DVD: have both NTSC & PAL - best source and settings?
By U2Joshua in forum Video ConversionReplies: 4Last Post: 10th Jan 2017, 00:28
