Good evening all
I'll try and be succinct here. I have a very poor quality VHS tape which I want to restore using Avisynth. I have a beginners/moderate knowledge of Avisynth but would like some recommendations from seasoned professionals. A sample of the uncompressed .AVI is at the bottom mega.nz link.
Capture process:
JVC SVHS > S-Video > Panasonic DMR ES-10 > S-Video > Diamond VC500 > Virtualdub Lossless capture.
Some examples of code/script would be greatly appreciated.
Thank you kindly.
https://mega.nz/file/Gt81lJAZ#NhQn8s8G2ugPW_ccyUUqmx-9uvBKw6ugamL_hTqMDfM
You havent really specified what you're looking for or what you hope to do with it. Do you want it cleaned some at the cost of detail? Did you want colors or anything adjusted? Do you care about detail? That kind of information would get you a better suggestion for your liking.
This is so poor looking, the most I would bother to do is get rid of the combing artifacts, crop off that garbage from the sides, see if rainbow visibility can be lessened if you see any, and resize it to proper aspect ratio. There isn't really too much you can do without destroying it more.
Code:LoadPlugin("C:\Program Files (x86)\MeGui\tools\ffms\ffms2.dll") FFVideoSource("C:\Users\????\Desktop\OTE99 RAW.avi", threads=1) ConvertToYV12(matrix="rec601", chromaresample="point") bifrost() QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", fpsdivisor=2, sourcematch=3, tr1=2, tr2=1, NoiseTR=2, sharpness=0.1) lanczosresize(640,480) crop(16, 0, -14, -4) # Adjust the amount of cropping as you see fit -
Here is the results of that script being used on the sample you provided. Depending on the changes you make and bitrate you choose, the results may vary. It certainly looks much better to me.
https://mega.nz/file/klxVTaRI#6SOYKuX58MTGyW4aJVnRpM-qO8tnNpf8Rxwy5kz8DZs -
I wouldn't decimate to 29.97 fps (remove fpsdivisor=2) unless you have playback restrictions.
Code:LWLibavVideoSource("OTE99 RAW.avi") AssumeTFF() Crop(20,0,-16,-4).AddBorders(10,0,10,4) # remove most of the junk at the edges of the frame, restore 704x480 ColorYUV(gain_y=30, off_y=-35, cont_u=60, cont_v=60) # levels/saturation adjustments ConvertToYV12(interlaced=true) QTGMC()
VHS Restoration in Avisynth?
By Andy2018 in forum RestorationReplies: 18Last Post: 11th Dec 2018, 22:41 -
Avisynth recommendations for vhs capture noise
By gamjerr in forum RestorationReplies: 6Last Post: 23rd Sep 2018, 19:51 -
VHS Tape Restoration for DVD Burning?
By ParadiseKendra in forum RestorationReplies: 11Last Post: 6th Jul 2018, 12:06 -
A strange request about Video Restoration
By lollo in forum RestorationReplies: 0Last Post: 5th Jul 2018, 05:47 -
VHS Tape (PAL) to DVD or the Best Format Conversion/Restoration Guide
By ConverterCrazy in forum RestorationReplies: 5Last Post: 18th Jun 2017, 22:33
