Hello all !
Iam searching for a way/program to shrink my MK4 File (approx. 35 GB) to a standard 25GB Blu ray disc (with that format to burn it). Ive tried several programs but always failed. Is there even a way to do this?
Ive tried DVDFAb (gets stuck at 85% reencoding). Ive tried remuxer and bluraydiscrebuilder - didnt work. Also with Handbreak i could not set a file size to 25GB, nor make a 25GB Blu ray disc format.
Even a simple mkv shrink would do to make it fit on a blu ray 25 data disc.
Freeware would be good.
Glad for your help, thanks in advance.
Spovkobob
Try https://www.videohelp.com/software/BDtoAVCHD and select bd 25 from the drop list.
No the time code of the video doesn't matter maybe your mkv is corrupted.
First remux your MKV with MKvToolNix - should only take a few minutes. This sometimes fixes errors. If that doesn't work post a MediaInfo report (text mode) of the file, this might show if there is a problem.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
It didn't work with MKVToolNix.
Format : Matroska
Format version : Version 4
File size : 35.9 GiB
Duration : 3 h 49 min
Overall bit rate : 22.4 Mb/s
Writing application : Lavf58.29.100
Writing library : Lavf58.29.100
ErrorDetectionType : Per level 1
Video
Format : AVC
Format profile : High@L4.2
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Codec ID : V_MPEG4/ISO/AVC
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Default : Yes
Forced : No
Color range : Limited
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Title : simple_aac_recording
Default : Yes
Forced : No -
I'm not sure what the conversion programs are looking for but what does stand out your audio track the sample rate is 44.1kHz Blu ray normally uses 24 bit 48 kHz audio. There are however some Blu-ray audio and concert discs that go up to 96 kHz and 192 kHz.Suggest you change the audio to 48kHz. You can do this in situ with a number of programs I use Popcorn Audio convertor https://www.videohelp.com/software/PopCorn-MKV-AudioConverter. So maybe the AAC 44.1kHz track is causing problems. 44.1 is normally associated with CD's
There is a free program that made it. It's called Video Compressor (2019).
I have compressed and converted the file to .mp4 , the audio is untouched. Now even my Samsung blu-ray media player device runs it well.
Thanks for help, it took a while but now i have found a good solution for me.
How to burn a blu-ray video disc using MKV files with these specs?
By robertazimmerman in forum Authoring (Blu-ray)Replies: 8Last Post: 25th Apr 2019, 22:14 -
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 01:11 -
Blu Ray to H265 mkv
By netmask56 in forum Blu-ray RippingReplies: 14Last Post: 3rd Jan 2017, 01:57 -
Convert MKV to Blu-ray
By chang123 in forum Authoring (Blu-ray)Replies: 11Last Post: 12th May 2016, 13:00 -
How to convert Blu-ray to standard DVD-Video (or MKV,MP4) using free tools
By Baldrick in forum User guidesReplies: 4Last Post: 22nd Oct 2015, 20:39
