I have a Sony MDP-600 Laserdisc player, and I was finally (after two decades) getting around to converting the content to digital files. When I tried to do so, the video was fine, but got no audio (my same setup works fine coming from a VCR). I moved between the two analog outputs, with no difference. I'm also getting no audio from the headphone jack. I tried switching from analog to digital audio, still nothing.
So I read I should try putting a CD in and playing that. So I did--and now the player will not spit out it out! I can put a laserdisc in, and it still plays (still w/o audio), but the CD seems to have disappeared. If I take out the laserdisc, I can apparently still play the CD (I see indications on the display that it's playing, but still no audio).
Does this unit have a separate CD player inside, and the disc is stuck in there? Help!
Doh! It just spit out the CD!
So, back to the real issue--why can't I get audio off my laserdiscs? I'm tried multiple discs with no effect. -
Ask and answer one simple Q. If you connect the same player and any LD to a tv do you get sound ?
And for the former. You have only, I guess, one disk tray but a CD is smaller than a LD and there could be a division in the tray for CDs. Just ensure that there is still not another one in the tray. -
What is the make and model? Some of the later laserdisc players had AC3 audio. I think some of them had a switch or menu item that turned that on/off.
Another feature is that my Pioneer laserdisc player has is the ability to play either the analog or digital track. It's been quite awhile since I played a laserdisc, but as I remember, if you set the player to the digital track, but you only had analog, you got no sound.
Will a JVC VCR "Stop" Playback if the video is "too grainy" or degraded?
By timepassenger in forum CapturingReplies: 8Last Post: 2nd May 2020, 08:17 -
What is the purpose of "Default" button in "Video" tab of XMedia Recode?
By MidnightUser in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2016, 04:08 -
"Blade Runner" Criterion Laserdisc
By Cuddly Squid in forum Newbie / General discussionsReplies: 17Last Post: 27th Oct 2015, 12:55 -
How i can encode audio of "REMUX" to "BluRay.720p.DTS" wit handbrake?
By VideoHelp4Ever in forum Blu-ray RippingReplies: 1Last Post: 2nd Jul 2015, 12:41 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21
