Recently the audio from my capture card has suddenly become really distorted for seemingly no reason. Here's a video showing what I'm talking about https://www.youtube.com/watch?v=uRoYyhiCFX8&feature=youtu.be. I have no idea how this could have happened because it was working fine a few days ago I have also tried using a different capture card but I'm still having the same problem. This has been happening on and off for a while now and I have no idea why.
Upload that clip direct here and not rely on any other issue that youtube has introduced by its re-encoding.
But you might have answered half your question yourself - you have eliminated ANY fault with the capture device.
So take the capture device out of the path. Connect the console direct to a tv with no splitter if you are using one. Same sound issue ?
If the problem persists then the fault is with the console and/or the cabling.
Sound is fine then reconnect the splitter if you are using one. Sound issue from the tv ?
If yes then you know the cause of the issue.
Is there a lossless video capture card that also captures 5.1 audio?
By end-user in forum Capturing and VCRReplies: 121Last Post: 15th Oct 2022, 05:41 -
Choppy video/distorted audio
By lsixecho in forum Capturing and VCRReplies: 1Last Post: 31st Mar 2019, 15:03 -
Distorted audio from VHS tape
By KortschKo in forum AudioReplies: 8Last Post: 29th Aug 2016, 19:05 -
HD PVR 2 Capture card has audio issues. Any solutions?
By super6646 in forum Capturing and VCRReplies: 0Last Post: 17th Aug 2016, 18:40 -
Video + audio capture card recommendation sought
By three_jeeps in forum Capturing and VCRReplies: 3Last Post: 10th Feb 2016, 15:48
