  1. Hello,
    I installed the K-Lite Codec Pack (15.4.8), but the codecs can't be found in VirtualDub. I tried both 32-bit and 64-bit versions. I tried to fix the problem with K-Lite tweak tool to no avail. What's the problem?
    I use Windows 10 64-bit.
    Thanks,
    Mark
  2. VirtualDub uses VFW codecs, not DirectShow codecs. Or just use VirtualDub2 -- it comes with a bunch of the common codecs you'll need.
  3. Oh ok, I didn't know about the difference between codecs. I installed VirtualDub2 and the codecs are found. Thank you for the tip!
    Never install codec packs!
