Hi
OK...... a few thing I know / have already
1) I know VHS is a real crappy format that the world and I have had to endure and suffer for many many years, even as a young boy, recording various TV programs I knew the result were total garbage quality wise (and that was on £1000+ panasonic vhs machines), compared to normal 625 line broadcast! why oh why did crappy JVC win the battle and not Sony Betamax back in the late 70s/80s,
JVC with there crap VHS offering caused decades of millions and millions of poor quality sub standard recordings.
2) ok now with that off my chest, I have a stack load of crap VHS recordings thanks to JVC winning the Video war, that i would like to archive, not really sure why because the quality of VHS is so poor, but for some strange reason, I would like to archive these memories, even though I will ALWAYS be disappointed with the results
I tried years ago with a Black magic intensity pro, USB3 thingy but with varied results, some not too bad.
I have now invested loads of $$$$ in a AJA Kona LHI setup and have a SONY SVO5800 VHS machine and I am feeding a SVIDEO signal in to the Kona LHI capture card, I also have a JVC 50hz CRT monitor connected to the output of the Kona LHI card for monitoring the input (VHS) tape being captured and monitoring the playback of the recording.
The problems I am facing is the over all quality of playback on any software player VLC etc.
when I view the captured recording on my 50hz JVC monitor its as good as the original, but when I view the same recording in windows its very average, I have tried turning on de-interlacing ? still not great, why is the digital playback in software of the analogue capture poor, even though I have captured the analog vhs at the highest raw video settings. I know my CRT has an electron beam scanning at 50hz and I have captured at 25 frames per sec. Is this what is missing in windows and why the CRT plays back so much better that windows, or do I need to do something to the raw copy ?
is it frame rate ? is it interlacing ? is it impossible to get analogue playing nicely on digital screens/computers/software video plays
I LOVE the 50hz CRT playback, on the JVC monitor, from the archived capture It's Crisp, Flow Nicely, it looks the same as the original
Why won't the PC playback look as good ?
why is this, I understand VHS is crap quality, but I am happy to accept the playback of my CRT 50hz pal monitor, it just the digital playback that's looks rubbish
is it the interlacing ? that when played back through software video player looks rubbish
is it that I recording in to high quality on the kona LHI, but NO..... i want to record in lossless, 10bit, I'm trying to archive ?
I'm sure I can see a slight improvement at 10bit vs 8bit
To make these archives play better digitally, do they need to be converted to a different format ?? i.e interlace / de interlace ??? Mpeg / MKV / Mpeg2
I don't really want to compress the result, I would like to keep lossless, but maybe for better results digitally I need to have a second compressed version ??
There are so many settings everywhere Digital / Analog / YCbCr / DVpro50 / ProRes422 etc etc
I'm totally confused and would like some help please
my current settings for capturing VHS on the kona LHI are as follows
PAL
file: abc123.mov file
Format: 720x575i (1.093) 25.00
Video: 10bit YCbCr ('V210')
Audio: 24bit LE PCM 48khz
now I think these are maxed out and the very very best I could expect to archive from VHS
So why is the digital playback so average VLC player
does this need converting / encoding to mpg / avi / MKV
I understand some of these are not codecs, they are containers for the video
But help...... just need some uncomplicated basic explanation of what I need to do
I 'm possibly thinking maybe analogue archives can not be played back that well / great on digital systems ?
I have a great VCR with TBC / I have a great capture card AJA Kona LHI / I am archiving at 10bit raw yet the digital playback is just ok ?
yet the analogue playback on the CRT is great
is it the scan lines/ the frame rate
Any Help will be very much appreciated
There is just to many settings / standards / codecs /etc
Regards
John
Results 1 to 30 of 65
Your old monitor is hiding the defects. Modern monitors and HDTVs accurately (within limits of personal settings) show the video as it truly is. In addition, your computer monitor and HDTV are probably much larger than your CRT, allowing you to see the defects even more clearly.
Post short clip of your actual untouched capture and others may able to help you with filtering and other settings. You're way overthinking and complicating things.Last edited by lingyi; 28th May 2020 at 11:22.
Hi
thanks for the reply
first what is the best PC software to take a small clip from a 2 hour rip? without changing the format. would like to edit the original but not change anything, so NO re-encoding.
I want to be able to place start and stop markers and then extract the video and NOT re-encode
I don't fancy paying Adobes GREEDY prices each month, I dont agree with monthly renting of software anyway,
I will only ever purchase software NOT rent, so what is the very best software to allow video editing? other than Premiere, one day Adobe will hopefully lose the market due to greed.
also I know you say I am over complicating things, but....I'm not sure I am, there are definitely interlacing to consider and refresh & frame rates
My JVC monitor size is roughly the same size as the PC video player window so lets rule out defects from physical window size between the real monitor and the PC player
Now the VIDEO I am watching on the PC that was captured from VHS is now almost ending, the credit are scrolling from bottom to top
I have paused the software player and I am looking at the text i.e. words I can see lots lines across the words, this is the interlacing, causing horrible defects on the digital playback
I dont get this on the CRT monitor,
also the CRT plays smoother, where as the PC player seem more jerky, delayed just not as smooth....
so what I am seeing is incompatibility between two systems analog vs digital
Now.... my super dooper AJA has capture analog and digitized it, but do I not need to re-encode to get rid of these interlace lines ???
Regards
[Attachment 53559 - Click to enlarge] -
Assuming you're on a PC, you can use Virtualdub or AVIDemux to cut a short sample.
My friend above stated 'Assuming you are on a PC'
Your earlier post suggested something else since we tend to regard a PC as a Windows machine. Noone here would capture anything as a .mov.
So let's cut the crap and state what your 'PC' actually is and, more importantly, state the hardware and software you use to 'capture' the VHS. -
Good catch on the PC. I forget and think of the computer world as PC, Mac and Linux.
The OP stated "...a AJA Kona LHI setup and have a SONY SVO5800 VHS" -
DB83... first of all
Whats the CRAP ???..... there is no crap....Your earlier post suggested something else since we tend to regard a PC as a Windows machine. Noone here would capture anything as a .mov.
A PC is a windows machine, never stated anything else ??
Why would no one here as You put it..... NOT capture anything as a .mov, explain yourself,.... They are lossless are they not ?
whats wrong with .mov its one of the default formats in the AJA KONA capture software, on $1500 capture card, I would imagine there not too much wrong with .mov ???
ProRes 422 is compressed,
so why NOT .mov ??
just googled .mov........ because no one here use .mov well not DB83
and this is the first thing that came up
There are various advantages associated with MOV format, which makes it much more popular and usable format for videos. ... In spite of the fact that MOV was intended for QuickTime player and MP4 uses the same lossy compression standards, they are mostly interchangeable in a QuickTime-only environment.18 May 2020
My hardware is more than, much much than respected for the job in hand.
Hardware is
HP Z640 WORKSTATION xeon 3.4ghz E5-2643 v3 @ 3.4ghz
64 Gig DDR4
Graphics 12gig Nvidia GTX Titan X Graphics Card
Primary Drive Samsung 500gig 970 Evo Plus NVM
Windows 10 64bit
AJA Control Room Capture Software
AJA Kona LHI Capture Card (Very respected)
SONY SVO5800 VHSLast edited by Johnnysh; 28th May 2020 at 13:15.
That's actually a pretty good capture for VHS. You have interlaced video. It needs to be deinterlaced for display. Time base is pretty clean. Minimal oversharpening halos. Levels and saturation might need adjusting. But those are all things you do after capturing.
Apologies if you do not understand the expression 'Cut the crap'. It simply means state the core problem (which you probably did) and not post 'flannel' which much of you OP is.
So to cut the crap do the following.
1. Upload a mediainfo report (text mode) of one of these captures.
2. Upload a sample capture from your equipment - even from Corrie (which many on here will never have heard of
And for the record you 'rubbished' .mov yet that is also a container format. In the days gone by it would have meant quicktime. Yet the whole point of a capture is not to be the end all of the process.
Throwing £££ at the capture hardware/software does not neccessarily make it any better than a £50 usb device. -
Jagabo
Thank you for your reply
now we are getting somewhere,
The SONY SVO5800 which blows away most VCRs has a TBC built in, its a broadcast studio quality VCR, so this is a major factor and a great starting point for good source quality
The AJA Kona Card is also well up there in quality..
look at these two images of the same frame from the captured video, one on the JVC monitor taken from my iphone and the other screen captured from the player software
[Attachment 53560 - Click to enlarge]
[Attachment 53561 - Click to enlarge] -
[Attachment 53563 - Click to enlarge]
these are the various file formats I can capture too ?
here is the file info you required, this is for the clip I uploaded
Regards
General
Complete name : C:\Users\HP-Z640\Downloads\3.mov
Format : QuickTime
Format/Info : Original Apple specifications
File size : 321 MiB
Duration : 11 s 680 ms
Overall bit rate : 230 Mb/s
Encoded date : UTC 2020-05-28 17:39:43
Tagged date : UTC 2020-05-28 17:39:43
Writing library : Apple QuickTime
Video
Format : YUV
Codec ID : v210
Codec ID/Hint : AJA Video Systems Xena
Bit rate mode : Constant
Bit rate : 221 Mb/s
Width : 720 pixels
Clean aperture width : 702 pixels
Height : 576 pixels
Clean aperture height : 576 pixels
Display aspect ratio : 4:3
Clean aperture display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 10 bits
Scan type : Interlaced
Scan type, store method : Interleaved fields
Scan order : Top Field First
Compression mode : Lossless
Bits/(Pixel*Frame) : 21.333
Stream size : 308 MiB (96%)
Language : English
Color primaries : BT.601 PAL
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio #1
Format : PCM
Format settings : Little / Signed
Codec ID : in24
Duration : 6 s 83 ms
Source duration : 11 s 680 ms
Bit rate : 2 304 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 24 bits
Stream size : 1.67 MiB (1%)
Source stream size : 3.21 MiB (1%)
Language : English
mdhd_Duration : 6083
Audio #2
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Audio #3
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Audio #4
Format : PCM
Codec ID : in24
Bit depth : 24 bits
Language : English
Other
Type : Time code
Format : QuickTime TC
Time code of first frame : 00:00:00:00
Time code, striped : Yes
Title : Untitled
Language : English
Tagged date : UTC 2020-05-28 17:39:43 -
Not the right way to send a sample but it can be corrected post-download.
The capture does indeed report Apple-quicktime (unless mediainfo has been 'fooled') and since it is lossless I guess you can not improve on that.
But you will be dealing with 'Huge' files which could be making post-capture 'interesting' to say the least.
Maybe you should state your final delivery format. -
So
from a PC software video playback Interlacing is one issue,
obviously the playback on the JVC CRT is perfect because the interlacing is correct for the CRT
but not so for the PC/software player
so can this be rectified (deinteraced) without losing any quality from the original archive.
are my dislikes down to this being a RAW copy which does not play great Digitally ?
regards -
I guess Apple Quick time is the codec being used in lossless format by AJA and the Control Room Capture Software
What I'm trying to Achieve is to archive VHS video tapes at the very best quality, (lossless / 10bit) and I also understand this will make large files, / very large
When I play back the captured video file and output it through the capture card on to the JVC CRT monitor, I can NOT FAULT or tell the difference between the source VHS tape, or the 10bit Archive
so all good there
my issue is, it does not play great on the PC / Digital player
its ok, but just ok....
I would have expected better, smoother play, smoother more defined image , no interlace lines or artifacts
as for final format, I don't know ??
I want the best lossless format, that looks and plays well on digital players
was hoping the lossless .mov file I have just captured would be the final archive huge file, but interlacing seems one issue causing artifacts
the problem is, if I compress to make it smaller you lose quality, the quality is crap at the best, so don't want to add more desegregation in the mix by compressing
RegardsLast edited by Johnnysh; 28th May 2020 at 14:22.
You can just force your player to deinterlace on the fly. Here's the video deinterlaced with QTGMC, the black level lowered a bit, and encoded as h.264.
jagabo
thank you for your reply
so... your encoded version seems better quality when viewing on the computer than my original, albeit my original is vastly larger
So what is it about the original lossless file that I don't like compared to your encoded compressed version that seems to me to favour better when playing and viewing on a computer
is it the h.264 codec thats doing something when encoding, to make the raw format play smoother and better in a software player
or
is it the interlacing ??
should I be choosing a different standard when capturing ?? apple proress 422 / DVCPro50, though thought I was choosing the best lossless settings already
I appreciate turning on de interlacing on the fly, but the players still do not seem to play my large raw files great ?
So are we saying I need to keep two files for the same VHS tape (1 HQ RAW Huge File) / (2 an encoded one that plays better on digital players) ?
and the next questions....
what is the best encoding software and what are the best settings for high quality results
Its all so involved and such a long winded process archiving hours of poor quality VHS, just trying to get it right before wasting load of time,
So really do appreciated any feedback
regardsLast edited by Johnnysh; 28th May 2020 at 14:43.
Visually, the difference between my video and your source is the deinterlacing. My video is also intentionally a little darker -- though that may not have been appropriate. It's possible the raised black level was intentional. QTGMC's default settings do sharpen a bit and reduce a little noise.
If you were to play my video on your TV you would probably get a look similar to watching the tape on TV. TV's are usually set up to stretch contrast and boost saturation. Because that's what people like. -
Hello
Thanks for the reply
so the bulk of what I am not liking is interlacing,
I may be wrong but QTGMC seems very complicated, with scripts and a large learning curve
or am I miss understanding,
what would be the script or commands to achieve what you did in conversion?
I have gone here
http://avisynth.nl/index.php/QTGMC
and wow, not sure where you would start
Regards -
Now....
your file is a fraction of the size of mine and what appears to be as good in quality.
so is my process still Right? for archiving even though interlacing is an issue, or should I be using a different format for capture,
my theory although files are huge, the quality at 10bit lossless should be the best,
but then I see your converted file a fraction of the size??
this all so confusing as to what is the best workflow to follow
Regards
I do appreciate any feedback -
Lossless files will always be larger than lossy. Typical lagarith/huffyuv files a 30 - 60 gb per hour. You chosen format is larger than that.
But the quality can be down to the efficiency of the codec compared with the visual perception of 'quality'. And since your captures are archival rather than delivery then you should always capture at the best your hardware will allow.
Difference in file size is attributable to one thing and one thing only. Bitrate. AVC (h264) is a much more efficient codec than quicktime and as jagabo stated both could look the same. -
So what are you saying then??
am I archiving in the wrong format ? even though I thought lossless was the way to go ?
should I be using apple prores 422 ??? but these are not lossless ?
regards -
You are cropping to 702, This might not be a legal resolution, It works in the computer environment but may not be compatible with some hardware.
For PAL I crop to 704x576, de-interlace with QTGMC and encode to H.264 using the following commend:
Most script apps work in 8 bit only so you may want to start capturing in 8 bit.Code:ffmpeg -i input.avi -vf "format=yuv420p,setsar=sar=12/11" -c:v libx264 -crf 10 -x264opts colorprim=smpte170m:transfer=bt470bg:colormatrix=bt470bg:force-cfr -c:a aac -b:a 192k Output.mp4
Ok Guys,
thank you for all your feedback, and please keep it coming, as I'm a little new to this, it's a lot of info to take in and get right all at once.
but your help is very much appreciated, thank you....
But, maybe I should be looking at this differently, are you saying
part of my issues and limitation is the capture software that AJA provided called Control Room! that i'm using to archive the VHS
I was under the impression this is the only software I can use to capture, thus being forced to .mov lossless files that this software (Control Room) offers
but ..... am I reading between the lines that other capture software can talk to my AJA kona card and offer a better lossless archive file format method of capture, outside of AJA Control Room software ??
possibly adobe premiere or alike
I was under the impression I'm forced to stay with Control Room Software? when arching/capturing
So are we saying other Capture software may offer better file formats and results ??
Oh I'm still confused,
regards -
Archive your orginal 10 bit 4:2:2. Make separate versions for watching. AviSynth+QTGMC is pretty difficult to get set up and requires Windows. I recommend you try using Handbrake first. Its deinterlacing isn't as good as QTGMC but it's similar to what most HDTVs do. On the Video tab set the Deinterlace pulldown to Yadif. The Preset to Bob. On the video tab set the frame rate to 50 fps.
Hi
Thank you for the feedback
I must say even though the last conversion you did was good, the first one was very very impressive not sure what settings you used, but wow
comparing the the two MP4, the first one processed in AviSynth+QTGMC is amazing and guess this is what I need to master, I have installed AVISYNTH on my windows video machine
just need to read up on how to use QTGMC, but very very impressed with your first result
so I guess what we are saying, is that the 10bit .mov 422 lossless file has the maximum info and data from the archive VHS. So this part is good.
But the PC / Windows / Flat Screen Monitor / Windows Drivers / Codecs etc etc
can not decode this RAW .mov file correctly and display the info nicely, as to way the first converted .mp4 file you did in QTGMC
Regards
VHS PAL Capture - Very minor pink noise appearing on sports capture
By Robertp in forum RestorationReplies: 12Last Post: 9th Nov 2018, 20:50 -
Input on VHS capture quality
By jtech1 in forum Capturing and VCRReplies: 3Last Post: 28th Feb 2017, 08:32 -
Can't capture signal from JVC HR-S9911U VHS deck into Hauppage capture card
By vhscapture in forum Capturing and VCRReplies: 3Last Post: 18th Jul 2016, 13:07 -
Capture card for VHS and coaxial (TV) / advice for VHS
By MrPeanut in forum Capturing and VCRReplies: 26Last Post: 25th Feb 2016, 00:06 -
VHS to PC capturing help please, screen flickers only on capture not on vhs
By Rdakin7593 in forum Capturing and VCRReplies: 7Last Post: 25th Aug 2015, 12:52
