What is the best way to do this?
I have tried creating a PAL project in Premiere and exporting it to 720x480 at 29.97 fps, but the video is all messed up (lots of problems when there is motion) when I burn it to dvd-r and play it in my dvd player.
What is the best way to covnert PAL Mpeg2 > NTSC (720x40 29.97 fps) MPEG2???
Thanks!
Bill
Originally Posted by bill55
or, look at the guides here and at doom9
you'll find your answer in one of these places -
I tried the guides but had no luck. Everything I tried came out with the same results.
I tried searching also, but could not get a clear cut answer to converting mpeg2 pal > mpeg2 ntsc.
Bill -
The guides here and at doom9 should provide most of the answers but one thing I will suggest is convert Pal to NTSC film (23.97fps) as this is a closer match. the resulting video will be played a bit slower, hence longer. You will then need to stretch the audio to match. I use sonic soundforge for this kind of thing and would recomend it if you can obtain a copy!
Couple questions regarding that.
Will it be noticeable when playing the video that it is slower?
Will it be dvd compatible? (I am making the DVD in DCD Maestro so I need it compliant for that).
Is there a way to convert it to 720x480 29.97 fps or do I have to convert it to the 23.97?
THANKS!
Bill -
No, you wont really notice the speed difference. I have done the opposite and converted 23.97 to Pal 25fps with no probs.
To make it DVD compliant you must apply 3:2 pulldown. If you use TmpGenc for your encoding, I would suggest doing video only with this and encode to 23.97fps, then apply the pulldown flags with pulldown.exe after the encode. An extra step I know but I have had more success with this than using the 3:2 pulldown setting in Tmpgenc. Then let your authoring program mux the audio and video
NTSC MPEG2 file to PAL M DVD
By Ed2009 in forum DVD RippingReplies: 2Last Post: 27th Sep 2009, 23:05 -
MPEG2 files - are they just MPEG, or are they either PAL or NTSC?
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2009, 15:07 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
converting hd pal mpeg2 to hd ntsc mpegs
By gearo in forum DVD RippingReplies: 1Last Post: 3rd Nov 2007, 18:26 -
NTSC mpeg2 to pal needed
By Caned_and_Able in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 21:13
