  1. I get a divx file I am trying to convert into MPEG to put on a VCD. I cant import the file directly into TMPEG. Also if I try to extract the audio in VDUB then it give me an error. I think it is because under the codec type it shows "Compression: Unknown (Tag 2000)" Not sure what I need to do to get the right decoder so I can convert this file into wave?? Any Ideas?
    Mar 2002
    chicago
    sounds like it's an AC3 sound...search for "wav from divx"
    there's good advice to be found
