I'm not sure if this question should be posted here, but...
Mostly out of curiosity, are there any (recommended, non-spyware/malware, etc.) Android apps that'll use your GPS location and data from sources like antennaweb (if that's still around; I didn't check before posting) to help you determine the best directions to point your TV antenna?
I never considered that such a thing existed but sure enough, they do. I just tried "Antenna Point". It's from a well-known retail operation, Antennas Direct but no ads so far. I like the way it works. When I have the opportunity to do so, I'm going to see if my indoor antennas are pointed as predicted by the app.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thanks, usually_quiet. I did give it a try.
Now, for anyone else reading this, your mileage may vary, so by all means don't let my experience necessarily turn you away from trying it.
It does have a slightly lower score in the Play Store, so read through the reviews and take note of the issues people mention, just in case. They didn't seem to affect me when I tried the app.
The app suggested pointing my antenna about... ~40 degrees off to the left of where I currently have it pointed? I tried that, but ended up losing a small handful of stations. And, as some of the reviews mentioned a possible issue with miscalibration/getting directions reversed, I did try pointing the antenna in the completely opposite direction. That didn't help.
In all, I guess I can recommend it, but don't necessarily use its recommendations as the final word on where you should point your antenna.If cameras add ten pounds, why would people want to eat them? -
In my case, the app did locate the towers with the strongest TV signals I receive and correctly indicated their general direction on its map. However, I found that I couldn't truly check the accuracy of the app's recommendation against how my antennas are now pointed. The tiny compass in the app is hard for me to use and I don't have a separate compass or GPS to accurately locate north.
As a side note, I originally used the TV Fool website to predict the OTA networks that I could reasonably expect to receive but it isn't being maintained and has not been updated to reflect the frequency reassignments in my area that took place in the past year. antennaweb.org is a better bet for an accurate prediction now.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Yeah, that's why I ended up with more of a general direction as opposed to having a more precise direction in which to point the antenna. Then again, I've never tried the compass feature on any of my Android phones, so I don't know how accurate they are, anyway. I need to dig the old compass out of my nightstand.
Originally Posted by usually_quietIf cameras add ten pounds, why would people want to eat them? -
usually_quiet you can use the old satellite trick, sun up in the east, point left hand there down in the west, right hand there. head straight and you are looking south. gets you a starting point.
Android Players vs LavFilters-MadVR? Looking to go to Android BOX
By therock003 in forum Software PlayingReplies: 3Last Post: 20th Jul 2018, 11:11 -
Android:i want to play this channel in vlc android application (vlc.apk)
By sam jack in forum Newbie / General discussionsReplies: 5Last Post: 16th Oct 2017, 16:10 -
download video playing in Android apps
By chisd in forum Video Streaming DownloadingReplies: 0Last Post: 7th Nov 2016, 04:47 -
Subtitle positioning - no positioning in the forst 10 boxes
By borianata in forum SubtitleReplies: 3Last Post: 19th Jul 2016, 05:20 -
Positioning
By suadnovic in forum SubtitleReplies: 7Last Post: 31st Aug 2015, 07:31
