Hi,
I have got some 4:3 letterbox mkvs, that I would like VLC automatically to "crop" to 16:9.
I am aware that this isn't real cropping, but I do know that VLC is able to use these MKV flags, so I wouldn't have to re-encode.
Anyone could tell me what the right options are?
Crop a total of 25 percent the height of the video off the top and bottom. For example 12.5 percent off the top, 12.5 percent off the bottom. The top and bottom borders aren't always the same size, so adjust accordingly.
It's in the cropping option in the video section.
[Attachment 53520 - Click to enlarge]
The GUI can show you the command line equivalent. -
If your video is h.264 (AVC) you can use a program called h264info to set the h.264 cropping flags. Most players respond to that. You'll have to demux the video to an elementary stream, use h264info to set the cropping flags, then remux to mkv with the audio. But VLC in particular seems to over crop if the borders are large.
Will a JVC VCR "Stop" Playback if the video is "too grainy" or degraded?
By timepassenger in forum Capturing and VCRReplies: 8Last Post: 2nd May 2020, 07:17 -
Why x264 "placebo" preset produce bigger file than "very slow"?
By aleaksunder in forum Video ConversionReplies: 21Last Post: 2nd Mar 2019, 07:25 -
What is the purpose of "Default" button in "Video" tab of XMedia Recode?
By MidnightUser in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2016, 03:08 -
How i can encode audio of "REMUX" to "BluRay.720p.DTS" wit handbrake?
By VideoHelp4Ever in forum Blu-ray RippingReplies: 1Last Post: 2nd Jul 2015, 11:41 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21
